Question about Refrigerators
Remove head from a rake
I want to remove the old rake head and replace the handle, however it seems impossible to get the old rake apart...whats the trick?
    Sergeant:
    Champion:
  • 278 Answers
The rivet through the metal collar also goes into the handle and head. drill out to remove.
Posted on Nov 05, 2012
Replacing new tines or a complete new drum
flexrake.com/1f-lawn-rake-head-only-flex-steel.html
Apr 29, 2014 | Flexrake Lawn Rake With 21 Flexpoly Lexan...
My gargen rake has a handle that screws into the head but it keeps coming out, how can I get it to stay?
I used to have this problem as well, what I did was put a little bit of wood glue into the hole and then screwed the handle back in. Let it dry for 24 hours and you should be good as new.
Jan 26, 2014 | Garden
What are rakes usually made out of?
most modern rakes that you will find at a home store will be made of steel or plastic with a handle made of wood or iron.
Delta shopmaster manual
if you want to remove the whole assembly take off the spring and tap out the lowering shaft. once that is done your spindle assembly will drop down,, with a little help.
Oct 07, 2013 | Drills
Litterbox is not working
Usually when this happens it is because there is something obstructing the rake making it impossible for the rake to go back to its original position. If there is nothing in the way, no clumps or bunched up litter, then the rake is not functioning the way it should. Sometimes gently pushing the rake back into its normal position can work. I had a LitterMaid that had this problem and every now and again I would have to "help" the rake with a push. If this doesn't work, then you have a defective litterbox that won't work not matter what... return it for another unit. Good Luck.
Nov 19, 2012 | LitterMaid Elite Basic - Advanced...
I have ordered a new battery cover as mine is broken .how do i remove the old one . it seems to slide up and down freely but how do i take it off to replace it ? thank you
I think you might have to take the entire cam apart into 2 pieces. try that. Just make sure you use the right screwdrivers or it might become impossible to take apart.
Mar 08, 2011 | Samsung S1030 Digital Camera
How to install a pontiac G6 driver door handle. The handle broke off. I opened the door panel and retrieve the broken piece. Got a new door handle, but it seems impossible to install it without taking...
Yeah, you have to remove the lock. Use an impact drill with the right phillips head to remove the screws. if you try to take them out with a screw driver, you will strip them. Remember...impact drill.
Nov 30, 2009 | 2006 Pontiac G6
Trying to replace the KHMS155LSS3 handle...
To replace the plastic handle on the KitchenAid KHMS155LSS-3 you pry open the door cover from the inside to release the upper tangs (~10). I used razor blades wedged between the tang point to hold them disengaged. Pull the front cover off the door starting from the handle end. Once the top edge is free, the bottom can be remover. See Pitcures.
Repeat the door cover removes with the handle attached from the front after you lift the tangs._828.jpg_829.jpg_830.jpg_831.jpg
Jul 26, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Getting door frame apart to install new handle
If you're replacing the handle, then order the choke cover..It's the piece on the inside of the door that covers the handle screws. No matter how carefull you are, it is almost guaranteed to break. If you break it, then you have one, and if not, send it back. DO NOT OPERATE MICRO WITHOUT CHOKE COVER.
Dec 09, 2008 | Kenmore 62702 Microwave Oven
Outside sliding door handle?
Yes. It is a difficult job, but not impossible. The hardest part is actually removing the interior door handle. Here are the steps.
  1. remove the interior door handle by pressing the door panel in and prying out the C-ring retainer clip
  2. remove the lock slide switch bezel with 1 screw, then insert a blade on the bottom left of the slider between the slider and bezel, and release the clip, the slide the bezel toward the rear of the vehicle and pull out
  3. carefully unclip the door panel around the lower edge and sides and lift the door panel UP and off
  4. remove the interior lock slide switch with 2 screws
  5. pull back the plastic vapor shield part way to expose the mechanism
  6. there is a cable that runs from the mechanism to the exterior handle, unclip it from the door frame
  7. there is a rod that drops down from the door handle to the mechanism, release the rod from the plastic clip
  8. locate a large (likely black phillips) screw next to the door handle on the EDGE of the door, remove it
  9. locate a 10mm screw on the inside behind the door handle, remove it
  10. locate the final 10mm screw behind the handle through an access hole, remove it (careful not to let it fall inside the door)
  11. the door handle will push out through the door part way- there is another C-clip securing the lock cylinder that will need to be removed, and the lock cylinder can be pushed into the door cavity
  12. pull the door handle through the outside of the door skin- the door handle assembly is still attached inside the door by the latch cable- the cable can be easily removed from the handle assembly to remove it completely
  13. you will likely find that the end of the door handle itself is broken off- don’t buy a new handle! Email me and I will show you my free and possibly better solution that will likely last the life of the vehicle dbonnell1972 at yahoo dot com
re-assembly is the reverse of the removal
Aug 13, 2008 | 1994 Toyota Previa
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
