Question about Insignia IS-LCDTV32 32 in. Television
My tv shows perfect but when it get hot it cuts off show for a few minutes and cut off again show a little and cut off
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
One of the circut boards in the tv has mess up,End will have to be replaced,
Posted on Nov 04, 2012
Merc E320 cdi cuts out on first few mile from cold 3 or 4 times
Throttle control sensor is where i would start.
Mar 16, 2017 | Cars & Trucks
Sime ecomfort plus 30 HE keeps cutting out and shows a flashing green light. Sometimes it will run ok for a couple of hours before cutting out.
I had the identical problem with the same model. Technician eventually diagnosed faulty fan; the fan cools the heat exchanger. When fan fails, exchanger overheats and boiler automatically shuts down. It is possible to restart the boiler when it cools down but when the heat rises again - off it goes! Only answer is to replace the fan. My technician did the same as yours - on first visit he got the boiler running and left. Half hour later, boiler shut down. I read the installation manual and operating instructions and when he called again I pointed him in direction of fan, which had failed completely. These guys!
Apr 11, 2012 | Televison & Video
TV cuts off w/o warning & power red light blinks continuously. Can cut TV back on but will cut off again. Sometimes it does this every few minutes and sometimes, especially in the evening, it will...
This may seem like silly answers but...
1. Be sure the power supply is plugged in all the way and that it is not damaged anywhere on the cord all the way up to the TV.
2. Be sure the Sleep Timer is not activated. You wouldn't believe how many times this is actually the case.
If these end up not the case then it is very possible that the safety circuitry in your TV's board could be going out. The TV is shutting it down due to it finding a problem with the circuitry in the TV. Most of the time people choose to replace the TV with a newer model as it is just cheaper to replace it than to have it repaired. This usually only happens in older TV's although I have seen it in TV's as little as 4 years old.
Nov 28, 2010 | Toshiba TP50F60/61 TV
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
Not getting a spark when I pull the trigger
Try checking the front Panel and Internal fuses, as well as the thermal overload.
This could happen when you exceed the duty cycle.
eg: 20% Duty Cycle In a period of 10 Minutes, 2 minutes cutting, 8 minutes not.
Best of luck
May 02, 2009 | Welding Tools
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV keeps turning off
You must Check Lopt Line output Transformer , Sounds it getting hot , then trip. If you are not a tv tech take it to one because there is heave high voltage there.
Jun 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Insignia IS-LCDTV32 32 in. Television Logo
60 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
