Question about Mitsubishi WS-65809 65" Rear Projection Television
My Mitsubishi WS-65809 turns on and then off after 4 seconds. I have pressed the input/enter together and got 2 and then 4 blinks. What do I need to do to fix it?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
First to be sure, unplug the set from power and then plug back--this clears the error buffer. Repeat the self check:
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
As you can see 2,4 is vertical problem----might want to remove speaker grill, inspection plate behind it and look up front--vertical is on middle board at right front as seen from front of set.
Look for ANY tiny drops of clear liquid which damages parts and is toxic-----glycol is what I would look for first.
Posted on Nov 05, 2012
  • thomaslooney
    thomaslooney Nov 15, 2012
    Hey bud you helped me alot and I would be more then happy to give you a vote but I dont know how to sorry but I have the 2 and 2 blinks problem would you please email the step by step info at thomaslooney78@gmail.com and tell me how to vote and tell me how to vote on here and I will
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi ws-65809 powers on for 2 seconds.
2,2 error code is short protection---98% of the time it means one of the two soldered in pico fuses this set uses is blown----there are several---but your problem means if it is ws-65809 one of the two stk-392-570 convergence chips has failed.
I will attach a photo---they are on the middle circuit board and the two to the right are for convergence--both are green and 5 amp--with the set unplugged check both of them like any fuse--no reading means bad.
If you find this--I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--SHOPS WILL GET 300 or more but you if you can do it yourself buy everything you need for under 40 dollars--I can tell you the best place to get the chips, fuses, etc.
If you want the instructions let me know and I will post them here for you---they are based on my own actual experience doing this repair in this kind of set hundreds of times.
If this information helped you rate this solution as I do this here for free.
SD TECH
Here is a photo of what the two chips look like--The one in the picture says 392-560 but yours uses two that look just like it--STK-392-570.
Posted on Dec 28, 2009
Testimonial: "SDTECH provided me the information I've been seeking for the past 2 years, and he did it the same day as I posted the problem. YEA!!!!!!!"
SOURCE: Mitsubishi WS 65809 65" Rear Projection TV. Turns
Hello There, Its seems that the circuit board has problems. You'll have to get it replaced ASAP before the board is ruined completely.
The same thing also happened to me 2-3 weeks ago. the techs came in and had to replace the board since 1 circuit was damaged.
It will cost around $100
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Posted on Jan 16, 2011
SD Tech
  • 14553 Answers
SOURCE: Mits ws-65809 Won't turn on Blinking 2 2
2-2 is a error code that means short protection.
Usually in this set it means one of the fuses that protects the convergence circuit is shorted because of a bad convergence Ic.
I HAVE PHOTOS OF THE FUSES-- and THE PROTECTION RESISTORS- and I also have step by step from start to finish instructions for this repair in this set.
If you want the instructions and photos give me a vote here and I will be happy to email them to you and answer any questions you have. I have done hundreds of Mitsubishi sets with this problem---I just got home from doing one a few miles away from where I live.
REGARDS, SD TECH
Posted on Sep 17, 2009
Testimonial: "Very Quick Informative Explanation specific to my question and model."
  • 126 Answers
SOURCE: Mitsubish WS-819 Protective Shutdown. 2 blinks, pause, 2 blinks
Over 95% of the time a 2 - 2 blink code on that model is a convergence output problem. You need to replace both of the convergence output IC's and perhaps the pico fuses feeding them voltage. The pico fuses are F9A04 and F9A05. They are on the same board with the convergence outputs.
Posted on Jun 02, 2009
Slinteriors
  • 8617 Answers
SOURCE: My Mitsubishi WS-65809 displays a 2 blink pause 2
tHats indicating a short. Check the two green pico fuses F9A04 and F9A05 on the center board if they are blown replace the two 5 amp picos and the convergence Ics.
Posted on Jun 10, 2009
I have a mitsubishi model ws-65809. i press the power button the green light comes on then it shuts back off.
IF YOU have unplugged it plug it back and try to turn it on, when green power light goes out:
On the front of the set press and hold BOTH the menu and input buttons at the same time--hold both for at least 5 seconds and release both.
This is the self check this set has: power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
The 2,2 error code is the most common and is short protection and I know if that code how to fix the set---for many customers it can be a do it yourself fix with parts cost under 35 dollars total.
Let me know what code you get and I will try to help you.
Fixed over 1,000 of these Mitsubishi sets.
SD TECH
Mar 24, 2012 | Mitsubishi WS-65809 65" Rear Projection...
My tv won't stay on.I pressed reset and input at same time.it blinks twice and that's it.
You have to press the menu button and the input buttons both in together and hold for 6 seconds then count the two digit blink code and let me know the blink sequence.
Jun 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Little dots are appearing on right side of screen started with one and now have eleven looks like a bug may be eating at it
Does the led blink a two digit blink code when you press the menu and device/input buttons both in together for 6 seconds? If so let me know the two digit blink code and i will assist you.
Jun 07, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi model ws65809 big screen tv. When I turn power on it only stays on for 10 seconds then shuts off. I checked the fuse but fuse was fine.I want to know if I changed the lamp will it fix...
You will need to press the menu button and the input buttons on the TV both in together for five secoinds then count the two digit blink code from the power indicator. the blink sequence will repeat several times. let me know the sequence of the blinks.
May 30, 2011 | Mitsubishi WS-65809 65" Rear Projection...
The Light turns on and then 2-3 seconds later turns off. Any solutions to fix it?
DO SELF CHECK IT HAS: WHEN SHUTS OFF PRESS AND HOLD BOTH THE MENU AND INPUT BUTTONS ON THE FRONT OF THE SET FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
POWER LIGHT WILL BLINK TWO DIGIT ERROR CODE LIKE: 2 blinks, 2 blinks, a pause and repeat 4 more times.
let me know error code found and I will tell you what it means.
SD TECH
Aug 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
In my WS 65809 projector tv, when I turn on the power, the green light clicks on for a couple of seconds, then clicks right back off.
DO THIS AND LET ME KNOW WHAT YOU FIND:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Ws 65809 wont power up at all Any suggestions to fix this Thanks problem?
does the led blink a two digit blink code when you press the menu and device/input buttons both in together for 6 seconds? If so let me know the two digit blink code and i will assist you.
Jun 22, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My Mitsubishi WS-65809 displays a 2 blink pause 2 blink sequence when the menu and input buttons are pressed and held at the same time. What does that indicate?
Jun 10, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
HELP
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Oct 20, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
258 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
