Question about Dryers
Dryer timer not advancing
We replaced a non working dryer with another used dryer that we thought was working just find. Now find that the timer does not advance. The clothes dry well and we know the vent is not plugged. We put on a different cord. Could we have put the cord on wrong?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
If the dryer is working fine and the timer does not advance, then the timer motor has gone out and you will need to replace the timer. Here is the part to order.
Posted on Nov 05, 2012
AlmostBob
  • 550 Answers
SOURCE: Maytag dryer MDE7400
depending on model, (mechanical timer or electronic timer)
Mechanical dryer timer has a tiny motor to advance it
many times service techs forget to plug in the timer drive motor when they replace the timer switch that it is screwed to
or they replace the switch when the switch is ok, but the motor is bad
Not a solution just something to check
the timer drive motor is a 2inch diameter press formed sheet metal device 1/2 inch thick on the rear of the timer switch
if there are wires hanging off, that is the solution
if there is no hum from the timer motor when you push the start button, replace the timer drive motor
electronic, not had one break yet
Posted on Aug 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: Timer does not advance, even in timed mode
My parts sources list 3 different timers for this dryer depending upon the MAN.#.
They are
33002855
33002808
33002854
Posted on Feb 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag Performa Electric Dryer Won't Start
Replace the thermal fuse and the high limit switch.
They come as a set.
Clean the auto dry sensor with rubbing alcohol.
Posted on Mar 10, 2009
  • 109 Answers
SOURCE: maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Posted on Mar 27, 2009
  • 15 Answers
SOURCE: Dryer air heats up but does not dry the clothes. Just replaced the timer but did not fix the problem. Air vents are cleared.
One of two possiblities:
1. Dryer vent is blocked - check the air coming through the outside vent
2. Blower Fan is clogged - remove the lower front panel and clean out the fan wheel
Posted on Apr 30, 2009
I have a Frigidaire Gallery Heavy Duty electric dryer, the dryer run non-stop even on auto-dry mode (timer doesn't advance) but the clothes aren't drying either.
Timer will not advance unless the element is working. Suspect bad element or bad thermal fuse on element housing
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Washing Machines
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
The timer on my Maytag DG212 dryer sticks and does not advance so it just keeps running.
You will need to change out your timer, as it is non-repairable.
Hint:...Be sure to get the same brand/mfg of timer, or be somewhat of an electrician because if you do not get the same timer it will not be wired the same.
Also only remove and replace one wire at a time, it will keep you out of trouble and ease the installation of the timer.
Please rate me
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer runs and heats fine. Timer does not advance.
Replace your timer, it is defective and non rebuildable.
Be sure to get the same type,mfg, etc...
Please rate me
Dec 23, 2010 | KitchenAid KEYS700LQ Electric Dryer
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
Whirlpool Gas Dryer Timer problem
OK, this timer is designed to spin in both directions and, if you have to advance this timer in any way to complete a cycle, you will need to replace this timer asap.
In most cases, the mechanism will fail, causing this non advancement stage(stalled timer mech).
replacing the timer will fix this issue.
Jun 01, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag electric dryer won't stop running.
temp selection switch is defective, replace.
nbcrca:)
Apr 11, 2009 | Kenmore 64902 Electric Dryer
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 | Dryers
Kenmore dryer dial doesn't advance
That looks like a thermal shut off to protect the dryer if it overheats.
I am assuming that the timer never advances - even in timed mode (as opposed to some automatic drying setting).
Most likely you need to buy an inexpensive multimeter and start testing. There should be a schematic on the back of the dryer either on the outside or on the inside of the back panel.
Since timers on dryers are just mechanical devices that use a small motor (and yours is brand new), it looks like your timer is not getting power. The switch itself is mechanical, you should be able to rotate it to the different settings, press the start button and the dryer will work in the correct mode. Without electricity, the timer won't advance.
Check for loose or burned connections. Dryers use a lot of amperage so occasionally the wires can get burnt and corroded.
Sep 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
87 people viewed this question
Top Dryers Experts
