Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: how can i use a usb cable with my lg banter phone?
from the userguide I found that you::
1. Press MENU, 9, 7
2. Use the navigation button to select a setting,
then press .ok
USB Modem/ USB Mass
Strorage/ Bluetooth/
Setting Reminder
select USB Mass storage to access files.
Good Luck
The User Guide can be found at
http://www.lge.com/us/mobile-phones/pdf/AX265%20UG%20English.pdf
search for PC connection mode
SOURCE: I cannot play music off my sd card on my lg banter phone
i think you need to re-program your phone
i hope in can help you
SOURCE: i locked my LG banter and forgot the lock code
I had the same problem you just need to type in the last 4 digits of your phone number :) hope this helped
SOURCE: i locked my lg banter
You
can
get the unlock code by contacting your current service provider
customer care department. If your phone is locked you can use any of
your friends phone to make this call. The
service
provider will then provide you the unlocking codes. Everything is done for free of cost and you are not going to be charged
for this process.
Another alternative is, you can take the
phone to any authorize phone service center to help unlock the phone,
because to unlock your phone, you will need some kind of software, USB
cable
etc to unlock the phone, so you can also go a nearby phone service
center to unlock the phone,
but calling your network service provider is the best because they have
the records of your phone and can easily help to unlock it. This are the
two reliable means you can unlock your phone..
