Question about Refrigerators
Samsung rs253babb water stopped working refridgerator freezes up
3 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: Samsung RS253BABB. Where is the water pump??? I
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Oct 21, 2009
SOURCE: My Kenmore 253 freezer/refridgerator has
kenmore coldspotmodel106. water dripping on top shelf.
Posted on Mar 19, 2011
Samsung RF217ACBP keeps freezing the ports inside the refridgerator. Then the fan motor starts
Their is a fan circulating air through out the unit. If this fan is not working you will experience what you have discribed.
Jul 21, 2014 | Samsung Rf217acbp Black 20 Cu.ft. 33"...
Samsung refridgerator rs261
If the temp in the 50/60 . To little info Freezer stop working. The first thing in Freezer side to melt is Ice Cream and Fish. 1st thing on freezer to check is the (Ice) Damper door closing all the way. Place a towel on floor and one when you get the ice. Get a 1/2 coffee cup of water pour in the shoot on top of the damper flapper if it hold water This is good. Close the door and remove the water by get ice. If the water pours out Not Good Replace the Damper assembly. It is letring in air and will freeze the evap up . 2nd there may be ice blocking the fan from turning. Bad sensor. Call Samsung get a tech out.
May 17, 2014 | Refrigerators
Kenmore 253 refrigerator/freezer won't stop running on any setting. The food in the top of the refrigerator would freeze unless I partially blocked the vent. I am wondering what the problem could be. i...
I have a Kenmore model 253 freezer/refridgerator upright model. I am getting cold spots in the refridgeration in and near the vegetable drawers on the bottom of the refridgerator. The icemaker works but the water dispensor has stopped working too.
Nov 28, 2010 | Refrigerators
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS253BABB. Where is the water pump??? I press the switch for the water dispenser and I can hear the pump running but no water comes out. The ice maker works so its getting water to the unit through...
Oct 21, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
