Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
New laptop want to connect but forgot key
Have a new laptop and cannot connect to internet because forgot password. what do I do.
  • 104 Answers
Hi.......Login to your router using http://192.168.1.1 Enter username and password.
Go to Wireless > Wireless security. Your network key should be there, labelled WPA Shared Key or Shared Key (if using WPA encryption).
Posted on Jan 04, 2009
    Scholar:
  • 157 Answers
What you want exactly?password for what? username and password for internet in subscriber? or just WEP for wireless key password?
if you forgot the password for username and password for subscriber....theres an option,i dont know what kind of subscriber do you have in your country...if you forgot the username and passowrd you can ask in the subscriber.
regarding in the WEP password for wireless,it doesnt matter,try this..
type 192.168.1.1 in the internet toolbar
username:admin
password:admin
and you can see the configuration,check the wireless settings for WEP...
5 Suggested Answers
  • 5 Answers
SOURCE: The password key
usually by using its IP address.
you will need to use a computer that is already connected to the router (internet)
open up internet explorer (or other browser) and in the address bar try the following:
http://192.168.1.1
http://192.168.0.1
http://192.168.2.1
http://172.16.1.1
http://172.16.0.1
http://172.16.2.1
also, i see someone recommends trying
http://192.168.1.254
it will ask your for a username and password which, unless changed during setup will be the router's default such as
admin/admin
admin/1234
etc
both the router's default IP address and default username and password will be in the instruction manual
Posted on Jan 27, 2008
marked
  • 6487 Answers
SOURCE: password
Since you forgto the password the best way to make this router work fine is to reset it and reconfigure it back, To reset it just press and hold the reset button for 15 seconds while the power is ON, then if you still have the setup CD just run and that should take care of everyting, but if you don't have the setup CD you can manually configure it by accessing the router setup page if you're not familiar on how to do that better call LInksys tech support and let one of their tech walk you through with that process they are open 24/7 this is the number 800-3267114..........
Hope that helps............
Posted on Sep 16, 2008
EmotionLess
  • 52 Answers
SOURCE: Forgot Wireless router password?
If you own the router and have adminstrative access to it, then you can easily change the code, but you'll need to connect to the router either via cable or some other laptop/pc which has the code to connect and change it in the wireless connection tab settings.
If you cannot do that, then the easiest way to do that is to reset router to default, which erases the password and you'll be able to connect to it and set a new one. Reffer to the users manual on how to reset your router to factory settings.
Posted on Mar 21, 2009
bschilz
  • 2049 Answers
SOURCE: Forgot my security password (network key)I need to
Logon to your router from your computer using your browser and going to http://192.168.1.2/. If it wants a username, the default username is blank and the default password is either blank or "password".
The Belkin management tool will come up. From there, go into your security and look to see if your passphrase is visible. If it is, you're good to go. If not, you can change it on that page save it and close out.
Don't forget to change the passphrase on any wireless devices you are using connected to the Belkin wireless router.
Posted on Nov 21, 2009
Hello, I recently purchased a new laptop (Sony Vaio, E-Series, VPCEB36FA). Whenever I try to connect this laptop to my home wireless network provided by a 6200 ADSL2+ 4-Port Zhone Router, it never gets...
Seems you forgot everything.
1. You could try the default username : admin with password : admin or username : user with password : user
2. if those not working you can reset your ADSL modem to the factory reset by push the "reset to default button" in the back panel, this will bring your modem to the very first time condition. Use the method 1 to login.
cheers
Feb 10, 2011 | Zhone (6218-I2-200) Router
Cant connect to wireless internet. Diagnosis tells me i am not plugged in. The wireless reception is excellent. When i connect my laptop direct to my wireless hub it works but without connection to hub no....
logon your ROUTER BY ENTERING IP IN BROWSER WITH ADMIN CREDENTIALS
OR IF YOU FORGOT PASSWORD THEN RESET IT BY RESET SWITCH TO FACTORY DEFAULTS
WHICH IS ON BACK SIDE OF ROUTER THEN CHANGE SETTING --SSID --WEP KEY
PUT A NEW KEY AND RECONNECT YOUR LAPTOP
Feb 05, 2011 | Dell Latitude D600 Laptop Computer -...
We just purchased another laptop computer and cannot connect to the internet. I forgot my password. I have netgear as my wireless. How do I find my password.
The WPA encryption key (password) configured in the Netgear router's wireless settings. Go to your router's wireless settings to get this key and use this key to configure the laptop's wireless card.
NOTE - To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 04, 2010 | Computers & Internet
Looking to connect awireless laptop printer and need the WEP or WPA key for the wireless network
WEP or WPA Key is the password for your wireless network.. it's the same password you used to connect your laptop to the wireless.. if yo forgot what it is, you might need to contact the manufacturer of the router or your internet service provider to reconfigure or re-setup your wireless network.. hope this helps a bit.
Sep 08, 2010 | Office Equipment & Supplies
I can not log onto my zoom router.....forgot my pass key for network need to add laptop
1. You will have to reset the router to factory default and run the setup wizard using your set up CD and create a new key.
Set up your laptop on the router using either the MAC address or a new password key.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 27, 2010 | Zoom (56600000) Router
I forgot my password to log into my computer
Dear friend ,
if your given password in booting time then you have to press DEL key and go inside the BIOS . change your settings. If you give your password in user then create new user and go inside the pc.Please clear me where you use password.
Jan 30, 2010 | eMachines eMD620-5133 Notebook
Ok i want to set up wireless internet on my wii but i forgot my password how do i get my password
You will have to reset your wireless router, to do this look on the bottom of the router for an IP address (example 192.168.0.1) now type that number EXACTLY as it appears into an internet browser address field, where the URL appears (firefox, internet explorer, chrome, safari). Then login to the router with your preset password. Now go to the wireless internet/network setup, each manufacture is different so it may vary a bit, but its basically the same, now go through the wireless internet setup and get a new network key (password you are referring too)
When done, give the router sometime to refresh about a minute or two, then enter the network key into the wii. You now should have internet on the wii
If you have questions or still can't connect there maybe more serious problems, contact me at my profile and I will be sure to get back to you.
Good Luck!
Jan 08, 2010 | ASUS Eee 4G Notebook
Forgot password to connect to the internet . Cannot connect my laptop to the internet without the password
For that you need to access your router settings
Connect your router to computer with ethernet cable.
Then you can access it with default link
http://192.168.1.1
or
http://192.168.0.1
for belkin routers
http://192.168.15.1
or
http://192.168.2.0
Type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration of router.
Then check wireless security then check WEP or WAP code add new code there if it is in * or# format then save settings and restart router.
So then you can connect internet with that new password.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 18, 2009 | Computers & Internet
I forgot my security password (ecryption key) of my WRT54GS. As a result I cannot login my laptop to the internet. Whay can I do next? I do have my original Lynksys CD but I use a IP phone connecting to...
You need to go into the wireless router settings, if you cannot see the encryption setting the you need to create a new encryption key and the configure the laptop's wireless card with the new encryption key so it can connect to the wireless router and Internet.
Oct 10, 2009 | Linksys Wireless-G WRT54GS Router...
My new laptop is asking for my "Network Key"?
hi,
your new laptop is asking a network key as you network(wireless) is a secured one.other laptops have this key already .in order to get the key,please open the internet explorer (or safari) in a working laptop and in the address bar type-192.168.1.1>>it will prompt you the username ,password page->>put "admin" as password and leave the username blank.once you logged into routers webpage,click on wireless tab and then click on wireless security subtab>>you can see the network key there.copy it or write down in a paper>>close that page.
--->>from the new laptop , try to connect,if it prompts network key--enter the key( you got from other laptop),and connect.it will connect and next time it will connect automatically.
thank you,
hary008
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
1,243 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
