Question about Plumbing
Ive got a shallow jet pump model sd510 it runs all the time and it pumps the water from our holding tank to sump pit it runs about 250-300 gallons through to the sump pit ive replaced the pressure switch and that still didnt do anything
  • Joseph Lukas May 11, 2010
    What happens after 250 to 300 Gallons, does the pump stop running? What is the problem
  • mike kirschbaum
    mike kirschbaum May 11, 2010
    Sometimes a small piece of debris will get stuck in the venturi, and the pump will not pump very well. Look into the inlet of the pump; the venturi gets very small, goes all the way to the impeller.
  • 104 Answers
Just curious, why do yo9ur run water from a tank to a pit?
Where is the pressure switch located? At the pump I presume? What will increase the pressure? If you are pumping to an open pit, you will never build up any pressure? What is supposed to restrict the pump to create pressure?
You need a restriction to create pressure to turn off the pump. Is there a float valve like in your toilet in the pit? If not this would be required
Good Luck
Posted on Mar 19, 2009
I have a 36 gallon utilitech water tank hooked to a 1/2hp shallow well jet pump my pump runs constantly and I think it's because my tank has no water in it any help would be greatly appreciated
do you have a pressure tank or what, are you doing a gravity type deal with a pump to back it up, all pumps need pressure tank too. or your pump will constantly be on or your tank fill hole is not tight a pump is designed to trip the breaker if it wired direct, if it is not wired direct like wired to an extension cord, then who knows what it will do burn up I imagine if it is constantly going on without water pumping thru it need more details
Nov 17, 2015 | Jet Plumbing
Why does the pump lose pressure? there are no visible leaks, of water or air
for the pump to lose pressure there has to be a leak somewhere please check and make sure you have a one way valve on the bottom of your jet pump that will not allow the water to run back into the well
Nov 29, 2014 | Utilitech 1/2-HP 9-GPM Shallow Well Jet...
Very low water pressure and excessive pump running
Clean electric switchcontacts with crocus cloth. Adjust higher cut in pressure on this switch.
Apr 12, 2014 | Wayne WATER SYSTEMS SWS50-12P 1/2 HP...
Do I have to hook my tank to draw water from my well?
A bladder tank is designed to give a certain amount of gallons of "draw down" before the pump turns on. The pump will work with or without a bladder tank but will come on every time water is used. Well pumps (Jet or submersible) can run for extended periods of time without causing harm to the pump, but a pump that turns on and off constantly will eventually burn out because it is so hard on the pump.
Jet pumps need to keep "head pressure" to efficiently create the vacuum necessary to draw water from the drop pipe, this is partially what a well tank does.
Feb 12, 2011 | Flotec Corrosion Resistant Shallow Well...
Hello, Our Flotec Shallow well Jet is installed in our basement a distance ( perhaps 50 feet or so from the well casing outside in the yard. The pump was installed as a replacement for a worn jet pump...
Hi, Tom, W/D here.
You shouldn't really need a check valve as the foot valve is in effect a check valve.
Next time that you are near the pump when it kicks on and you are using no water, let it achieve full pressure and kick off. Close the discharge valve, isolating the pump and suction line. Watch the pressure gauge. If the pressure falls, you either have a leak in the suction line, possibly a leak at the well head (sucking air), a leak in the casing riser pipe or bad foot valve.
If the pressure holds steady, open the discharge valve and note the pressure. If it falls immediately upon opening the valve, the leak would be on the house side if the pump. Look then for any sources of water usage (ice maker, drips in the tub, water from the pop-off valve at the water heater, etc.).
Best regards, and good luck.
If I can be of any further assistance, please post back.
Jan 22, 2011 | Flotec Corrosion Resistant Shallow Well...
Just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
May 27, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Flotec 42 gallon water tank - short cycling and changing water I need a new tank or could it be another problem?
These holding tanks are pre charged with air which in turn pressurizes the water. The tank has a bladder and an air valve on top. The pre charge ,over time, loses pressure, and the tank has to be pressurized again.
  • The well pump needs to be turned off.
  • The water has to be drained from the tank
  • Air is put into the tank from the air valve on top of the tank, and is measured with a tire air gauge.
  • The pre charge pressure is set to two psi below the pump cut in pressure.
  • In other words if your pump kicks on at 30 psi, the pre charge pressure is set at 28 psi. If the pump kicks in at 20 psi, the pre charge is set at 18psi, etc.
  • After you pressurize the tank, turn water back on.
  • If water comes out of air valve on top of tank, then the bladder is ruptured and you need a new tank.
  • Hope this helps!
Jul 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Pump 30/50lbs pumps up to 50 shuts off pressure drops to 32lbs
Look for a place in the pipe from the pump to the house where an air pocket could form. That will fool the pump.
Mar 29, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
164 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
