Question about Midwest Can Company Midwest Can Midwest 31733 5 Gallon Spill Proof Gas Can 5 Gallon
Using the midwest 2 gallon gas can model 2300
How do you get the gas from the can to the gas tank of the car?
HOW DO I FIX THE CAR AFTER WATER WAS THROWN INTO THE FUEL TANK?
have to remove the gas/water in that is in the tank by removing the tank so you can turn it upside down and make sure every drop of the gas/water is out of the tank siphoning it out may leave some old gas/water in the bottom of tank then get rid of it let the tank dry out for a day and reattach it, then refill your tank with gas it may screw up for a little bit until the gas/water trapped in the fuel line is totally gone.
Go to you tube and look up "removing gas tank"
Dec 12, 2015 | Cars & Trucks
Fuel filter location?
most are in the gas tank.
Easy job if you have a floor jack, 2 floor stands and wrench.
Empty the gas tank, place jack centered on the gas tank jack up the car, put the floor stands in place to hold the car steady, disconnect the wiring go to the gas tank then remove the bolts (most cars only have 2 holding the tank braces, slowly lower the floor jack with the tank on it, remove the fuel pump slowly and carefully as not to have anything fall in the tank.
https://www.youtube.com/results?search_query=remove+gas+tank
Dec 10, 2015 | Cars & Trucks
How do I disconnect gas tank from the line that fills the tank?
How to fix a leaking gas tank - YouTube
? 7:20
www.youtube.com/watch?v=Luj6qPuxIPM
Mar 10, 2013 - Uploaded by FastestIntegra How to clean and fix a leaking gas tank. ... i repair rusted gas tanks with fiberglass putty, works really well, i have a car that i fixed 7 years ago ...
Sep 27, 2015 | Cars & Trucks
How to remove fuel tank
Procedure to remove a fuel tank depends on brand, model and year of the car. Just some examples:
How to properly remove gas tank
How To Remove Gas Tank
How To Remove The Fuel Tank
How to drain your car fuel gas tank
What is the gas mileagefot my car
1. Fill gas tank 2. Record odometer reading 3. Drive car as usual until 1/4 full. 4. Fill gas tank and record how many gallons it took to fill it again. 5. Record new odometer reading and subtract original reading. 6. Divide miles driven by gallons used.
Mar 09, 2013 | Cars & Trucks
I have a 40 gallon rheem water heater for a mobil home that is leaking from the top.
If water heater is leaking, then open following 2 links to avoid tank rupture and troubleshoot leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Water-heater-is-leaking.html
Open following link if you want to install your own gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
40 gallon electric heater at Lowes costs 207, and is easy do-it-yourself using same basic information shown in link above for installing gas heater, except less work.
To have gas water heater installed, can run $2-300 for installation plus cost of heater.
40 gallon natural gas water heater at Lowes starts at $300+, and tanks with longer warranty cost more and last longer.
Trailers require specific type of gas water heater, so be sure to request correct model.
If you maintain the tank: keep chemicals out of same room as gas water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean gas burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Apr 08, 2011 | Water Heaters
How many gallons left in the gas tank when the fuel warning light comes on?
I would say between 1 and 2. Usually it is 2 gallons of gas, 40-50 miles worth.
Feb 19, 2011 | 2003 Toyota Camry
Message center says "Fuel Computer Failure", gas gauge drops from 1/4 to empty - car runs out of gas. Fill tank with gas and car runs fine. 2005 LIncoln LS V8.
hi,
Im looking online and its looking like the sending unit in the gas tank, this tells the computer how much fuel is in the tank. its in the gas tank with the fuel pump. the gas tank has to come out and its a pretty straightforward easy weekend job. get yourself a haynes or chilton manual for the lincoln at the auto parts store. run it out of fuel again and follow the procedure for tank removal in the book or google it. spray the gas tank strap bolts with wd-40 too. have a garden hose and fire extinguisher handy .
good luck
jm
Aug 19, 2010 | 2005 Lincoln LS
Midwest Can Company Midwest Can Midwest 31733 5 Gallon Spill Proof Gas Can 5 Gallon Logo
266 people viewed this question
Top Midwest Can Company Garden Experts
Dennis Key
Dennis Key
john h
Are you a Midwest Can Company Garden Expert? Answer questions, earn points and help others
