Question about Baby Lock Sewing Machines
Automatic threader came apart can you sew with it broken?
  • Baby Lock Master
  • 7,365 Answers
You should be able to,, I never use mine.
Posted on Nov 05, 2012
yalmer
  • 552 Answers
SOURCE: how do I use the
http://www.singerco.com/accessories/manuals.html
singer manuals.
http://www.singerco.com/resources/
singer operation basics
Posted on Apr 15, 2008
  • 323 Answers
SOURCE: singer 2932 automatic threader
A new part is faster and easier but sometimes the problem is a bent hook( the tiny part which goes through the eye of the needle). Remove the needle to see the part better and pull the threader down. Look in the very center of the threader for the hook. It is probably pushed to the right.Using a small screwdriver or other thin piece of metal, force the hook back to the center. Try it and continue until it enters the eye again. By the way, a Singer dealer can get this part for you for under $10.
sewman7
Posted on Aug 11, 2008
informatica
  • 1114 Answers
SOURCE: do not know how to
Hi - You can download the manual by clicking the link underlined in blue below:
XL-2600
See page 26:
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 14, 2008
SOURCE: broken prong on built in threader
You won't even look at my problem unless I pay you money but you want me to tell you, for free, how I fixed the problem? Doesn't seem fair to me. I will post my solution on a free forum. Sorry to all you folks looking for the solution.
Posted on Jun 23, 2009
SOURCE: Janome MC 10001 auto. needle threader stuck in up position.
I have a Janome 10001 and the needle threader is stuck in the down position and I cannot get it up. Help, please !!!!
Posted on Jan 11, 2010
Automatic needle threader
Usually, the needle needs to be raised so the needle eye will match the threader. However, perhaps your threader has been bent or inadvertently pushed up or out of position.
Jun 06, 2017 | Sewing Machines
Can the automatic threader be fixed can i do it myself?
Depends what is wrong with your needle threader. Needle threaders tend to be very fragile parts so it is not uncommon for them to stop working. You may be able to replace the part if it is broken but it may be a job trying to find the part. Search the internet for parts for the make & model of your machine. Once you get the part, search the internet (YouTube) for videos showing how to replace the part.
On the other hand, it is not a serious problem if the auto-needle threader does not work. These options were not available until the most recent sewing machines were manufactured and your machine will most likely operate for many years despite the broken needle threader. Manual threading was all that was available for over 100 years.
HINT: To help make needle threading easier, lick your forefinger then swipe the back of the needle's eye. The moisture in the eye will help pull the thread through.
Nov 11, 2015 | Sewing Machines
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
The automatic threader does not work
Please refer to page 33 of the user's manual.
The needle has to be in the highest position for the needle threader to align with the eye of the needle.
Threaders will not work if the eye of the needle is too small for the wire on the threader.
Sometimes the wire gets bent if it was forced against a needle that was too small or if the needle was not in the correct position for the threader to work.
The wire can be bent back into place, but you have to be careful as it is very thin and can break.
If the wire is broken, the dealer can order a new threader - they are not very expensive and are easy to install.
Feb 19, 2010 | Brother XR-65t Mechanical Sewing Machine
Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Nov 22, 2008 | Bernina Virtuosa 150
Sewing Machines Logo
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
