Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
LG French door refrigerator the door that releases the ice is not opening
The ice maker is working fine but the door that releases the ice is not opening.
  • bwaits24
    bwaits24 Nov 06, 2012
    Our ice maker seems to be working fine. However when you try to get ice from the dispenser in the door, the chute fills up with ice but the little door that releases the ice isn't opening. Any simple solution?
    New Friend:
Happened many times to me over the years there is a spade connecter that has become dis-connected from the vibration.Pull out bottom tray(mine),Unhindge the ice shute.The outer shell will then pop out with moderate effort.Unplug the wire harness to the display then remove about 4 screws and a cover will come off exposing the loose wire connection to the solinoid valve,I suggest crimping the female connector until it fits quite snug.Then re-install hardware.
Posted on Dec 11, 2012
3 Suggested Answers
  • 161 Answers
SOURCE: LG LRFD25850 French Door, Fix or Repair Daily
You are expereincing poor service. The techs that are working on your unit do not know what they are doing. There is no problem that can't be resolved on appliances. My suggestion to you is to find a really good LG tech in your area to repair this problem. There are only so many things that can cause these problems.
Posted on Jan 22, 2010
heatman101
  • 43501 Answers
SOURCE: LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
LG LFC23760SB Refrigerator doesn't have power. The outlet is ok. Didn't have a power surge.
i think there is problem with your compressor unit. You need some maintanance or service of your refrigerator at regular period.
Jan 03, 2014 | LG LFC23760SB Three Door French Door...
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
LG LFX 25950SB, the Ice Maker is not working, just hear a click
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
115 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
