Question about Lionel Cw 80 Transformer
Reconnecting tranformer wires (red & black) to underside of FasTr
Which posts do I slide the connectors on under the FasTrack? They were accidentally pulled out.
The red wire goes to the center terminal, and the black to the outer one.
Posted on Jan 25, 2010
I have a hunter 29185 remote control and the connector on the 9v battery broke off. Can it be repaired?
Yes... absolutely.
Your handy dandy electronics store... used to be Radio Shack..
That (real) old garage door opener in the bottom drawer...
any snap set that has the matching black/red connecter wires...
Red to red
black to black... a little heat shrink tube and some solder and you are back in business...
God luck.
Aug 19, 2016 | Hunter Fan Televison & Video
Power failure of motherboard
"power failure of motherboard"
I'm lost. Since when does a motherboard produce power?
Power failure AT motherboard?
You have tested the 3 main voltage power rails, coming out of the Power Supply?
A) 3.3 Volts DC
B) 5 Volts DC
C) 12 Volts DC
[In comparison two D cell flashlight batteries produce 3 Volts DC ]
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
[ From http://en.wikipedia.org/wiki/Computer_power_supply ]
http://www.gigabyte.com/products/product-page.aspx?pid=2439#ov
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
ALL Orange wires are 3.3 Volts
ALL Red wires are 5 Volts
ALL Yellow wires are 12 Volts.
ALL are DC Voltage
ALL Black wires are Ground wires. Means Negative wires. ( - )
All power wires named above are Positive wires. ( + )
(This is a DC circuit)
Multimeter:
Positive (Red) probe lead to power wires, one at a time.
Negative ( Black) probe lead stays connected to ANY Black wire.
Looking at the Playtool link, observe the photo to the Right.
Shows 24-pin ATX main power cable plugged into motherboard.
This is what you want.
The Back of the connector is where the wires go in.
The Back of the connector, is where the straightened out paperclip goes in.
I straighten out a paperclip, and insert down into the socket hole; of the power wire to be tested.
(Orange, or Red, or Yellow)
Straightened out paperclip, slides RIGHT NEXT TO the existing wire.
Look at middle photo. See the Front of the connector? You can barely make out the ends, of the female metal terminal connectors.
This is a closer look,
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction
At the bottom of the photo is the Front; of the female metal terminal connector.
At the Top is the Back of the connector.
The straightened out paperclip, MUST slide down into the socket hole; far enough to touch the Back of the connector.
Now do the same for ANY Black wire.
Power Supply now plugged into power, you can now touch the multimeter's probe leads, to the straightened out paperclips.
Two paperclips used at one time.
Test each voltage power rail, one at a time.
When I state Voltage Power Rail;
3.3 Volt power rail.
ALL of those Orange wires end at one central point, in the Power Supply; the 3.3 Volt power rail.
This means you can test ANY Orange wire, and be testing the 3.3 Volt power rail.
Same goes for the 5 Volt power rail. (Red wires)
Same goes for the 12 Volt power rail. (Yellow wires)
What are the voltages? Post back in a Comment.
OR,
Use a KNOWN to be good, Compatible power supply; for a temporary test unit.
Power Supply checks out OK, or you are using a KNOWN to be good, Power Supply?
What do the Electrolytic Capacitors look like? See any bad ones?
(Radial Aluminum Electrolytic Capacitor)
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 25, 2013 | Gigabyte GA-M61VME-S2 Motherboard
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
How to correctly install batteries in ultra model 1000ap?
Place your two new type CB1270 batteries on their sides, one on top of the other in front of you with the battery connectors closest to you and with the battery connectors to your left. Connect the short (2 inch) jumper cable between the two center battery posts (1 red/1 black). Slide the battery stack into the chassis with the battery posts to your left as you face the front of the UPS and be careful that the battery posts do not touch the metal chassis. When the batteries have been slid completely into the chassis, connect the heavy red wire from the circuit board to the red battery connector at the bottom of the battery stack and the heavy black wire from the circuit board to the top black battery connector. If you have doubts about your wiring, use a DC voltmeter set to the 50v range and touch the red probe to the red battery post at the bottom of the battery stack while touching the black probe to the black battery post at the top of the stack. The reading on your meter should be somewhere between +24 and +26v depending on the charge level of your batteries.
Nov 04, 2010 | Ultra (ULT31502) UPS System
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Switch diagram needed
Funny, I came here because I just opened up the switch case on my MM875. Hold the switch so the terminals are on top. Call the black switch (the part you push in to power up the mower) north. The north post gets white (metal connector). The west post gets red (plastic connector). The east post gets the black that comes from the mower's motor (plastic connector). The south post gets the black that comes from the outlet (metal connector)
(Black Plastic Switch)
White (Metal)
Red (Plastic) Black (Plastic--from motor))
Black (Metal--from outlet)
May 22, 2009 | Black & Decker 19" Electric Lawnhog...
Gateway 400vtx - Reconnecting laptop monitor to laptop base
Find the location of the GPU. The connector should be located near it.
Mar 14, 2009 | Gateway 400VTX-3501335 Notebook
Installing acoustic research ar94 speakers
Appart from the wire clips what type of connectors are there? are they RCA like on a TV?
If you are driving these speakers with an external amplifier then the red and black cable clips are your safest bet.
these connections are designed to carry an amplified signal. Unlike the RCA connections which are normally Line level.
Dec 30, 2008 | Electronics - Others
Plenio vxa-2000 antenna pinout
If you are looking at the external connection end with it in a "V" position, on the right - the upper one is green & the lower one is red. On the left - the upper one is yellow & the lower one is black (or the big bunch of copper wires). Be sure you are reconnecting an exact pin set up - an s-video is not the same (unfortunately). If you found a replacement antenna or a correct replacement part, please let me know where. I have to repair mine too.
Oct 27, 2008 | Digital Video Systems Plenio VXA-2000 GPS...
Lionel Cw 80 Transformer Logo
1,467 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
