Question about Car Audio & Video
Fosgate reset switch for T400 amp - Car Audio & Video
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Amplifiers do not have reset switches. If you feel you need to reset it, just disconnect power to the amp for a few minutes.
Posted on Nov 05, 2012
I have a fosgate 15' sub and a fosgate t1001bd amp in my chevy tracker, how should the amp be hooked up and where should the ohms be set?
You can not set the ohms, If you don,t no what your doing get help from some body that noe,s what in the hell there doing, That you don,t fry the amp, End blow the sub,
Nov 12, 2012 | Car Audio & Video
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
Where's the fuse located in a Fosgate p300-1 amp?
It is just to the right on the rear of the amp next to the 12 V + - RTO +
Here is a link to a picture:
http://www.crutchfield.com/S-mj0Klw5sfLm/p_575P3001/Rockford-Fosgate-Punch-P3001.html
Feb 14, 2012 | Rockford Fosgate Car Audio & Video
My punch 400.4 amp stopped working is there a reset button or a fuse on the amp
there is no reset button the amp check fuse on the amp wire make sure it's not blown
Jun 04, 2010 | Rockford Fosgate Punch 400.4 Car Audio...
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
Reset switch
MORE THAN LIKELY UR ANP WENT INTO PROTECT MODE 2 STOP IT FROM SHORT CURCUITING, CHECK ALL UR WIRE THAT HAVE POWER ON THEM.
Mar 20, 2009 | MTX XThunder 704X Car Amp
Rockford fosgate bd1000a1
There is nothing to reset on this amp, it has no microprocessor.
Resets for electronic equipments are for clearing any software glitches that the microprocessor uses to do complex functions. I have only seen microprocessors in a couple of Kenwood amplifiers, and I have fixed many Fosgate amplifiers including this model. If you are not gettng any sound from it, you may have a blown channel. It is the most common failure I have seen in these. If that is the problem with yours, you need to take it to a service center that works on Rockford Fosgate amps, they have output transistors that are mounted on what is called a "mesha rail" and you can not change out just the 1 or 2 that are shorted, you must replace the entire rail because the transistors can not be removed from the rail and there are no generic parts for them as well.
I hope this helps you with your problem, deciding what you can do with it. It is a very good amplifier and in most cases it is worth the repair cost. You can not get a different amplifier of the same quality for less than the repair cost which usually runs about $125 at my shop.
Let me know if I can be any more help to you.
Dave
Jul 03, 2008 | Rockford Fosgate Punch 800a2 Car Audio...
Amp
There is no reset button. If you disconnect all of the speaker wires from the amplifier's speaker terminals and unplug the RCA cables, does the protect light still come on (I assume that you've already replaced the fuse)?
Jan 12, 2008 | Rockford Fosgate P6001BD Car Audio...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
