Question about Microwave Ovens
My father just got a new microwave and there is a hole burnt through the plastic box on the lower right hand side
    Problem Solver:
  • 18 Answers
Return it, and contact the manufacturer
Posted on Nov 04, 2012
I have a GE WES1384SM2SS microwave oven that shoots fire out of the right hand side.
Sounds like it is arcing there. Is there a plastic or Mica cover there?? If so that is the wave guide cover and it will need to be replaced and any and all carbon burn marks totally cleaned out to be able to save the machine. You can remove the burnt cover and run the unit with a container of water in it to see if it still arcs. If it does more cleaning will be needed if not, replace the covers with new ones and you should be good.
Aug 12, 2017 | GE Microwave Ovens
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Microwave door has burnt patch: is it safe to operate?
From your other post:
The paint should be available at big box stores like Wal-Mart, home improvement centers like Builder's Square, Lowe's, or Home Depot, or hardware stores or local appliance parts stores.
You can order the plastic sheet (called the "door film") here. It is part # WB06X10490.
Be sure the mesh is clean and dry before installing the new film.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | GE JVM1653 Microwave Oven
Burnt hole in microwave
Is the hole actually bigger than it originally was or is it just empty because the rack support got burned up & discarded?
The rack supports / rack holders can be ordered. The part number is WB06X10140 (or WB6X10140) and they're less than $5.00 each. You can find them in stock here.
If you install a new rack support in the hole, then any gap or hole around it can allow grease to accumulate, and that can lead to arcing. But you can seal it safely & easily.
Once the support is installed and everything is squeaky clean and dry, you can apply a small amount of silicone caulk into the gap or hole.
Let it dry it overnight with the door open, then use a razor blade or X-acto knife to gently trim away any excess caulk.
That would be a really good fix.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave (inside on right hand side wall) has a plastic cover. Behind this cover while popping popcorn there was bright yellow/red flashing/light, it started to melted the plastic cover within seconds....
You don't say which make/model microwave you have, but on every model I have ever seen the thing that sits behind the plastic cover is the magnetron - the bit that actually generates the microwaves.
Unless the microwave was a fairly top-end model, you might well be cheaper to just buy a new one.
Hope this helps,
Matt
Mar 27, 2008 | Microwave Ovens
Microwave
A microwave needs all those surfaces to be fully reflective. those scorch marks greatly affect the magnetron. it will soon burn out . reccommend a new microwave.
Feb 17, 2008 | Microwave Ovens
Light bulb burns hole in the plastic cover
Same issue here. I just bought 4 covers from RepairClinic.com for $5.50 US each. I shipped them to my PO Box in Buffalo for an extra $6 bucks. Part number was 1206433
Hope this helps
John
Dec 23, 2007 | LG LMVM1945 Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
