Question about Zephyr Venezia ZVE-E30 Kitchen Hood
Would you know how to replace a bulb for a Venezia hood. I can't find the exact specs for the replacement bulb JDR E27 110V 50W
  • addisonn Jan 21, 2009
    I'm having a tough time finding replacement bulbs. I've ordered from eBay, but the quality is questionable. I ordered 4 bulbs and they burned out so quickly. Any other ideas?
    Problem Solver:
  • 5 Answers
Chris, I googled and found this
http://www.plasmaled.com/household_led_light_bulb.htm
probably available at a lightbulbs unlimited or other lightbulb store.
Maybe even a Home Depot or Lowes.
Posted on Jan 07, 2009
Bought LED 8w(50W) bulb for range hood, bulbs work fine when turned on to regular mode but don't work on the second setting that supposed to make them a little dimmer. Do I need dimmable bulb or is this...
not a bulb problem, the computer board is what makes the light dim. for the price of replacing the main board i would just let it work the way it is. if the light fails completely, then think about a new board, but its not really a thing that is needed.
Dec 30, 2013 | Maytag MZD2766GES Side by Side...
How do I remove burned out light bulbs from zephyr range hood? What do I replace them with?
What model range hood do you have? To remove most of the bulbs from a Zephyr hood, wait for the bulb to cool after use. Then rotate the bulb counter-clockwise about 60 degrees (less than a quarter turn) and the bulb should drop down. If you have problems turning the bulb, try the glass suction cup that comes with the hood or a rubber/latex glove grip. Sometimes a rubber jar grip will also work.
The one way to find out your range hood bulb may be to remove one and look at the side/back. The bulbs are labeled. Otherwise, check your manual. Zephyr has the manuals for most of their ranges here: http://zephyronline.com/customer_support . Use the drop-down menu to select your model.
Different hoods use different bulbs. For AK6500, 6536, 6542 Cyclone hoods, purchase type: 4OR 14 mini flood light bulbs. For the AK2500, 2536 hoods, you need to purchase type GU 10 halogen bulbs. For the Anzio models, including the ZAN-E30AS, get a GU-10 50W halogen bulb.
I hope this helps.
Oct 14, 2011 | Kitchen Ranges
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
I need a replacement bulb Zephyr Pyramid range hood, I cnnaot find it anywhere.
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
www.zephyronline.com
Jul 30, 2009 | Zephyr Pyramid ZPY-E30 Kitchen Hood
Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Feb 05, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona
The bulb is a JDRC E27. Google it and you will find various places to get it, such as BulbConnection.com or DivineLighting.com. I would recommend buying 3, because if one has gone, the other will go very soon (my experience) and then you have an extra in case you drop one or one of them fails soon. Shipping will be the same, so the more you buy, the cheaper the per-item shipping. Home Depot does not carry them. Also, I don't know the differrence between the JDRC and JDR, so if you get the JDR version you may be displeased. Also, before getting the LED types, check the brightness... when I bought mine, the LED's were not very potent, so I stuck with the Halogens. However, they are very warm.
Apr 23, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
Feb 17, 2008 | GE Monogram ZV30SSF Stainless Steel...
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
Zephyr Venezia ZVE-E30 Kitchen Hood Logo
405 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
