Question about Toshiba Satellite P755-S5385 15.6 Intel, Satellite
My toshiba satellite p755 keeps shutting down
  • Toshiba Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Nov 05, 2012
cpenzes
  • 1102 Answers
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Posted on Feb 09, 2009
Joed911
  • 4338 Answers
SOURCE: TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
SOURCE: toshiba satellite p10-832 shutting down
Go to the following link... Best
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1931079&BV_SessionID=@@@@0393765923.1216012797@@@@&BV_EngineID=ccchadeeilhefeecgfkceghdgngdgmm.0
Posted on Oct 12, 2008
  • 42 Answers
SOURCE: I have a toshiba Satellite laptop that all of the sudden has started shutting down on me when I am in the middle of something. What could it be?
Depends. When you say it shuts down, do you mean it flashes blue and then shuts off / restarts, or just plain shuts off, and stays off?
If it is flashing blue real fast, then shutting off, here's what you do:
While starting the computer, press F8 as soon as the brand logo goes away, and keep pressing until you get a screen that says Safe Mode on it. Then highlight the Disable Automatic Shutdown option, and hit enter. Use the computer until you get the blue screen. It will give you an error message, followed by a stop code. (0x0000ce or something like that). Get that error code, and bring it back here. I'll tell you what it means.
If it is simply turning off without warning, and stays off, most likely it is overheating. In which case, head to Wal-Mart, go to the computer section where the keyboards are, and pick up a can of compressed air. Blow out the computer right where you see the vent on the side (maybe on back), and try that. If that doesn't work, get a laptop cooling pad and use that. If it still doesn't work, then the heatsink for the CPU needs to be recompounded, in which case take it to a shop. Unless that is you ABSOLUTELY know what you are doing and can do it yourself. IF YOU HAVE NOT TAKEN A LAPTOP APART BEFORE DO NOT ATTEMPT IT WITHOUT A PROFESSIONAL, YOU WILL BREAK IT.
Let me know how it goes, and i'll try to help you further if need be.
Posted on Apr 29, 2009
  • 211 Answers
SOURCE: need to know how to dismantle Toshiba Satellite
Here is Toshiba Satellite P105 (which is the same as P100) disassembly guide.
Just follow instructions by scrolling down, then go to page 2, 3, ...
Posted on Sep 02, 2009
The battery run down without no use and when you boot it, it will shut down by it self, and is booting slowly.
If this is a new laptop, you need to migrate your data off it and get it replaced. Something is draining your battery, or the battery is bad. Keep the power cable plugged in and save what you need. Contact your vendor customer support for a replacement.
Mar 17, 2015 | Toshiba Satellite P755-s5320
Automatic on toshiba p755
Not sure what system you are talking about. If you are saying that your Toshiba is automatically powering on then you may have a feature called wake on LAN enabled. Press the key at power on to go into your setup menu, look for the wake on LAN (sometimes called magic packet) feature under power control and disable it.
Feb 11, 2014 | Toshiba Satellite P755-s5120 Core I7 Pc...
How to factory reset my Toshiba satellite laptop P755-S5120, core i7, 64bit plese help me.
Go to BIOS setting through the Bios setting Key eg F2 and click on file then select set to Default.
Oct 04, 2013 | Toshiba Satellite P755-s5120 Core I7 Pc...
Shut down automaticaly
Not much to go on, "shut down automaticaly" on battery or AC or both? A computer will shut down, or hibernate, if thats what you mean, that's a power setting? If a computer overheats it will shut down automaticaly to save the components from heat damage. If there is dust in the fan and vents it will shut down. If it is not getting sufficent air flow from vents on the bottom of the laptop through the vents on the side. One option is a Laptop Cooler.Is it shutting down when you are on it? When it's left unattended? Respod to this post for further assistance.
Nov 19, 2012 | Unknown Toshiba Satellite P755-s5385 15.6...
Keeps shutting down
Nov 04, 2012 | Toshiba Satellite P755-S5380 15.6-Inch LED...
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Toshiba Satellite P755-S5385 15.6 Intel, Satellite Logo
1,151 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
