Question about Music
How do i transpose on a korg c 303 - Music
2 Suggested Answers
  • 5603 Answers
SOURCE: Need help connecting Korg C-303 (Concert Piano)
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
Posted on Aug 29, 2009
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
Please guys badly need yourhelp,have korgx50 problem is the tuning suddenly transpose up and down,and almost 50% of the program effects are not working properly maybe the IC is not functioning thinkso
I had an old organ/keyboard repair man tell me 95% of his repairs were diodes over 10 years old. Everything else was switches, capacitors & transformers. Hope that helps.
Aug 25, 2015 | Korg X50 X-50 Keyboard
KOrg X5D is out of tune
Did you try to get to Global mode, and then check if the tune is 440 hz?
Check the Global Settings. The tuning might either be altered or the key transposed..
May 05, 2013 | Korg X5d
The pitch of my korg x5d is D#, how can i get it back to its original set up
Press:
1- GLOBAL
2- PAGE+ or PAGE- ,untill the display show "TRANSPOSE".
Set the value to "0" using YES / NO or VALUE slider.
Apr 11, 2013 | Korg X5d
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
Pitch bender failure.
That is NOT a very descriptive problem statement... If all notes are off pitch but the bender still varies the tone, read about "transpose" in your user manual. Often the transpose or even the A440 setting gets changed and synth will be off pitch. If the pitch bender causes NO change then the control may have a failure.
May 13, 2011 | Korg Pa2X Pro Synthesizer
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Keyboard seems to be stuck in key of D How do I get it back to C ?
On page 105 of your X5D manual, read up about "transpose". Setting the transpose shifts the notes plus or minus from the normal.
If you don't have a manual, you can download one for free.
Nov 13, 2010 | Korg X5d
KORG C-303- power doesn't always connect or cycles off and on
The contacts MAY be bad in the switch, in spite of it "clicking".
Test the switch with a continuity tester.
Oct 17, 2009 | Music
Need help connecting Korg C-303 (Concert Piano) and Korg Symphony Model O3 (Orchestra Module). Have no documentation for the Symphony module.
May 12, 2009 | Music
Music Logo
62 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
