Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
Replace lost button
Lost a button, how do I find a replcement part?
Lost one of the four buttons, where can i get a replacement?
Goodluck!! The only place to get that is to send your watch to the manufacturer to fix it.
Dec 19, 2013 | Adidas Digital Hot Pink Rubber 50M Ladies...
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
I've lost the chronograph button above the winder. Where can I buy one on line and does it screw back in. Thanks. Edmond
mcdevito75, Best Bet with your Chrono watch is, check out a small watch repair shop in your area for that btton and replacement. A smaller watch repair shop may save you some money on costs.
Jun 22, 2010 | TechnoMarine Ceramique Watch TCB02C
The release buttons on the clasp of my Rado Jubile wrist watch have lost their spring tension can it be fixed
mcdevito75 here, Best Bet with your Rado watch, Look for a small watch repair shop in your area for adjustment / replacement.
Jun 21, 2010 | Rado Diastar Anatom Jubile watch
I have lost the instructions and cant set the time
Try Googling (pod)(548)(manual) without parens.
Aug 04, 2017 | Watches
Casio cmbi watch with didgital timer and normal clock on
I lost my instruction and need to set my watch to the correct time. It is a casio illuminater AW-80
Oct 26, 2008 | Casio AW80-7AV Wrist Watch
Setting the time on a bench watch
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Oct 16, 2008 | Watches
No sound
Is your battery indicator showing a full charge? Sometimes if it's not showing full then the sounds are disabled. If it's not full tape it to the inside of a window for a couple days and see if that gets the indicator up to "full charge" Otherwise you are going to have to send it in to have it repaired.
Jul 27, 2007 | Casio Databank DB35H1AV Wrist Watch
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
48 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
