Question about Kenmore Washing Machines
Kenmore 70 series washer model 82871420 only runs on rinse cycle
Only rinses, spins & drains
  • Bradd Smith Nov 04, 2012
    Does the motor run when the timer is in wash?
  • scamperoni
    scamperoni Nov 04, 2012
    all it took was loosening the back panel. Started running only on warm/warm cycle, then all!
Is the timer going through the wash time? Is the motor running but nothing happening? If the motor is running, then either it has not shifted into wash or the transmission is broken. An electrical coil shifts the transmission, it could be bad, or the trans it self is shot, time for a new washer.
Posted on Nov 04, 2012
  • 249 Answers
SOURCE: Kenmore 70 series washer will not drain
sounds like the timer to me
Posted on Jun 16, 2009
lsteward68
  • 331 Answers
SOURCE: kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Posted on Jul 10, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Posted on Jul 26, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore 70 Series Washer
The lid switch is bad . You can either replace it , or bypass it under the control panel . Try putting a pencil down into the hole on the top where the lid actuator goes into to see if it drains and spins .
Posted on Aug 20, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 01, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
heatman101
Jun 01, 2010 | Washing Machines
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Jul 26, 2009 | Washing Machines
Kenmore series 70 washer leaks during rinse?
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series will not rinse pleave advise how to fix this problem
If the machine agitates, spins and drain ok I would try different cycles and if some work and some don't change the timer. Timer is model 3951166 and runs for around 112 dollars Availible here only: http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11022422100&productCategoryId=0153200&brandId=0582&modelName=AUTOMATIC WASHER, COMPACT A/W&diagramPageId=00002&componentDescription=CONTROL PANEL&documentId=P0102319&backToLink=Return to Sub Components list
Nov 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
