I have a comfort glow model CJ26PL propane heater when i turn it on to high it works good for prolly 2min then the mediun side burner like blows out and wont stay lite so i can only run it on low after that?
  • 3 more comments
  • Brian Nov 07, 2012
    What are the air shutters ?
  • Joe A H. Nov 08, 2012
    It is a round metal plate that mounts over the orfice and has a slice of pie shape opening
    that moves to make the opening bigger or smaller at the back of the burner by shutting down the air that is drawn into the burner with the gas from the orfice.
    by closing the opening it makes the flame smaller and not trying to blow off of the burner and away from the thermocouple.
    Here is a link for the manual and Tech support phone #. http://www.allpartsinc.com/mmAllParts/Ot...
    Sergeant:
    Novelist:
  • 185 Answers
If it has air shutters on the burners try turning the air down. also you may want to check gas pressure. LP on the average has 10 to 11" of water colume. If it is higher than you will need to turn the gas pressure down..
Posted on Nov 05, 2012
  • 3 Answers
SOURCE: heater lites then goes to low flame will not stay on high flame
Pilot sensor or thermocoupler
Posted on Feb 04, 2009
SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Posted on Feb 13, 2009
  • 77 Answers
SOURCE: i have a comfort glow
you have a fuel flow problem somewhere. you need someone with a flowmeter and an ounce pressure gauge to check all your regulators and control valve.
Posted on Jan 22, 2010
SOURCE: I bought a comfort glow vent-less space heater
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
Posted on Feb 20, 2010
  • 240 Answers
SOURCE: I have a Comfort Glow
Hi. Thanks for your question.
  1. Remove the screws that hold the front cover in place along with the front cover. Hold the pilot control down and ignite with a lighter. Keep the pilot engaged until thermocouple is warm enough to keep pilot gas flowing. If it will light this way then you need to blow out the pilot orifice. It seems that every year I have to go in after the summer season when the heater is off and clean the pilot/orifice lines with high pressure air. I believe spiders/bugs/dust block pilot orifice when it is not in use. You can also tell that orifice is blocked when you don't get a good blue pilot flame with pressure behind it allowing the flame to submerse the thermocouple. If the the thermocouple is not getting enought heat it will turn pilot gas off for safety reasons.
  2. Or the oxygen depletation sensor has failed. When it fails it cuts all gas flow as a safety precaution. Because the sensor is built into the gas flow control it is not servicable and requires a replacement. These are the weak point on all ventless gas heaters and fireplaces.
I hope this helps you out.
Thank You for using FixYa.
Posted on Jan 17, 2011
How can I adjust the flame? I have the CGCFTP and one side of the flame is higher (alot) than the other side. It's burning the top of the metal insert.
Normally, you can raise and lower the flame height, with the Control Knob (Wider the white stripe the higher the flames. Narrower the stripe, the lower the flames). But, I don't think that's your problem. From your description, it sounds like the burner may be clogged or there is a air shutter control problem on the open end of the burner. This controls the air to gas ratio. Also, depending on the age of this Compact Classic Firebox and whether or not annual maintenance was preformed regularly, the burner may be shot entirely. Since DESA International, who made the Comfort Glow line for Lowe's, went out of business in 1999, we know the heater is at least 2 years old, minimum. Although, I suspect yours is an older model, based on the Model Number you provided. If you feel comfortable troubleshooting it yourself, I have provided a link to your Owner's Manual, in case you have misplaced yours. You can down load and print it for future, as well as for any parts you may need.
http://www.desatech.com/manuals/Fireplaces/model_CGCFTP_manual_111044-01L.PDF
If you don't feel comfortable repairing it yourself, contact your propane provider. As most propane providers also do service and repair for this type of Vent-free Gas Fireplace.
Hope this helped to steer you in the right direction.
Mar 17, 2011 | Desa International CGCFTP Compact Heater
Where can I find a propane to natural gas conversion kit for a comfort glow model cgr30p?
I would try Shopzilla.com/heaters I have found several hard to find items ere. Maybe not the cheapest best I've been happy dealing with them. Good luck ,thank you and have a good holiday
Dec 24, 2010 | Desa International CGR30P Heater
I bought a comfort glow vent-less space heater model # CJ18NL. It had a natural gas valve on it and the guy said I could put on a propane valve, which I did. It's not lighting. Is this model only good...
Good Luck
Feb 19, 2010 | Desa International GWP20T GLOWARM Wall...
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
Where is the model # located on my Comfort Glow propane heater?
Just went down in the basement and checked on mine. Looking at it from the front there is a lable on the left side near the bottom. Mine has the model right on the top of the label. CBN18C is my model number, your should be similar to that, only it may have a LP instead of the N mine is natural gas....
Heatman101
Jan 08, 2010 | Desa International CBN30T Central Heating...
Flames out the top of my propane top heater.
either it is rusted out or you need to blow out and clean your orffice
Nov 30, 2009 | Cars & Trucks
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Sep 10, 2009 | Desa International Comfort Glow Infrared...
Heater wont work on high setting
Clean the burner with a wire brush and vacuum the ceramic. Blow out the heater, remove dust, cobwebs, and lint from it.
Oct 19, 2008 | Desa International GWP20T GLOWARM Wall...
Heating & Cooling Logo
176 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
