Question about Marantz Pmd661 Portable Field Flash Recorder Pmd-661
My Marantz 661 reads "unformatted" on the recorder screen. How can I get my audio to play?
Use 8 gig sd card
Yes you can simply replace 4gb card with 8gb, 16gb, ect...
the device doesn't know the difference, it just gives you more storage capacity... hope this helps?
Mar 02, 2015 | Marantz Pmd661 Portable Field Flash...
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
Zoom h1 handy recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
When I arm a track to record in tracktion 3 I get a delay when monitoring playback.
If you monitor the recording there are two delays... one as audio is converted and stored... the next is when it is retrieved and converted back to audio. Usually the recording interfaces have a monitor function that loops the audio back out before the conversion. playing back previously recorded audio of course will have the delay to retrieve and convert back to audio.
Jul 03, 2011 | Mackie Onyx Blackjack 2x2 Recording...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Hi I have a marantz pmd661 with a buzz on record when set to ext mic/line with no i/p regards
If you let the input "float" with no connection it very well may buzz. The input needs to be tied down with a driving source.
Feb 15, 2011 | Marantz Pmd661 Portable Field Flash...
The memory card says unformatted card
Refer to your BR manual for procedure to format the card. Formatting the card in a PC just doesn't cut it.
Look in your index in the manual for "formatting" or "card"...etc.
Apr 13, 2010 | Boss Micro BR Digital Recorder
I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Nov 16, 2009 | Boss Micro BR Digital Recorder
C.d burner has stopped working on my BR1180
As long as it indicates program content in the memory and can play the audio through an am p or headphones you should still be able to record the content onto your computer and burn it from there if your computer has a burner. I use Audacity which is a good freeware program.
Jul 14, 2009 | Boss Micro BR Digital Recorder
Marantz Pmd661 Portable Field Flash Recorder Pmd-661 Logo
20 people viewed this question
Top Marantz Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Marantz Music Expert? Answer questions, earn points and help others
