Question about Tiger Electronics Furby Model 70 800
There is no on-off switch - just a reset switch. The instruction say to hold him upside down, press his mouth switch and press the reset switch at the same time. This does not work. he does not com
I checked for the on-off switch, and there is none - only a reset switch. I removed the batteries and tried the instructions again, and it did not work
  • sunnystainedglass Nov 06, 2012
    According to the instructions, he should work, but does not come on.
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Nov 27, 2014 | Samsung SyncMaster 913N 19" LCD Monitor
How to unlock rca tablet
1. Turn your tablet off.
2. Hold volume up and power button at the same time.
3. Wait until the android dog screen pop up and then the android upside down with a triangle in it will come up the you hit reboot with your volume up or down button and press power for ok.
Mar 01, 2014 | Tablets & eReaders
Reset password htc phone
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME UP and DOWN buttons, and then briefly press the POWER button.
  2. Wait for the screen to show the instructions on how to do the factory reset, and then release the VOLUME UP and DOWN buttons.
  3. Follow the instructions onscreen to factory reset your phone.
Sep 06, 2013 | HTC Tablets & eReaders
How do you reset a furby
probably first turn your furby upside down. by the battery holder you will probably find it.
Apr 23, 2013 | Tiger Electronics Grey Furby Electronic...
Screen upside down on a panasonic CF-T8
On any Panasonic Toughbook you can rotate the screen as follows:
Hold down the "CTRL" and the "ALT" keys and while holding down
these two keys press the "UP Arrow" key and then release all
three keys. This will reset the screen so it is right side up instead
of upside down.
Good Luck and regards from:
Richard, Authorized Panasonic Canada Toughbook Dealer since 1989.
P.S. The arrow keys look like this: The up arrow is the one on the top
Apr 23, 2012 | Panasonic Toughbook Computers & Internet
We got a game stuck in the wii consele....We tried ejecting the game as well as turning the game off...nothing is working.
You have to try out all these options first:
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds.
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
If none of this works, you might wanna try this, but it is not a preferred method, if you ask me, even though it can be done.
To remove a disc you'll need three sets of tweezers. And possibly a bobby-pin.
First you need to turn the Wii upside down (and preferably unplugged from a power source)
Second, using two sets of tweezers, press the small metal "guards" down. These are located just inside the mouth of the Wii. They're there to keep the disc from free falling, and inhibit their removal. They aren't locked and shouldn't be difficult to press down.
Third, you'll need to reach "up" through the middle of the mouth with the third set of tweezers to grab hold of the disc. I'd highly recommend using flat tweezers, not sharp ones as the disc may become scratched.
NOTE: The disc itself rests on the internal carriage (through the center hole of the disc) and if upside down, should fall into your tweezer's grasp easily. If it doesn't then you need a bobby pin to dislodge. Gently press the bobby pin on top of the disc and then grip the disc with the tweezers.
Finally, gently pull and the disc and push on the bobby pin and the disc will slide out easily .
This can be done with one person, but helps if you have an extra hand.
Good luck.
Sep 23, 2011 | Nintendo Wii Console
I forgot the password for my htc touch phone, i have tried my usual passwords also..but nothing helps. please suggest something to unlock it.
I am afraid the only way is to "hard reset". But note that this will erase all your data.
hold down the Send and End Call buttons down firmly and push the stylus up in the little hole near the usb port (Reset Button) and wait till the screen says that the phone is going to format and all data will be lost press the soft key to continue.
Mar 02, 2011 | Cell Phones
I bought a used Nintendogs DS game for my daughter and would like to reset it. Anyone know how?
Pu the game in , turn your device on hold A, B, Y, X, L and R. Keep holding it down until it says "Would you like to erase?" also you may need to hold the stylus in your mouth when you press all these buttons start the game and then confirm you like to reset the game , Thanks
May 05, 2010 | Nintendogs: Dachshund & Friends for DS
Formating the system
Do you hard reset where it wipes the whole of your phone memory?
If so - backup your stuff before attempting this as this will wipe EVERYTHING! I use PIM Backup (which is free)
1. With your phone on. Pull out your stylus.
2. Hold your Touch Pro upside down.
3. Press and Hold the VOLUME DOWN and ENTER button (D-pad), then press the RESET button with the stylus tip till message appear
4. To HARD RESET, Press the VOLUME UP button to perform the hard reset, or else press any other button to cancel.
5. Then just follow all the screen instruction to continue…
This will revert your phone back to it's stock (i.e. out of the box) settings. Then just restore your backup file you made
Mar 13, 2009 | HTC Touch Pro Smartphone
Lexmark x644e LCD Display Upside Down(Inverted)
Hello there,
I've seen this before. The X64X series with this inverted display seems to work fine (printing,scanning,faxing..) the reason for this is still unknown. But I've got it fixed twice by resetting the NVRAM on this MFP. If you are unsure of how to reset NVRAM, please follow the instructions below:
1.Power off the MFP
2. Hold down the 6, 7 and 8 buttons down and turn the MFP On.
3. Please hold down the buttons till it reads resetting factory defaults and then release the buttons. The MFP should now come back to ready status.
Please check out if this solves the issue, If not the machine would need a hardware service.
Merry Christmas!
Dec 18, 2007 | Lexmark T632 Laser Printer
Tiger Electronics Furby Model 70 800 Logo
Top Tiger Electronics Toys Experts
Jim Goldsmith
Jim Goldsmith
Tom Chichester
Are you a Tiger Electronics Toy Expert? Answer questions, earn points and help others
