Question about Nordic Track Nordictrack 2500 R Treadmill Drive Motor
Nordic track 2500r anx when u walk on it pressured applied the motor will lock up step off works fine
  • 18 Answers
SOURCE: How do you replace the walking platform on the
First, remove the motor hood. There are 3 screws at the front, and 2 underneath. The screws underneath will have to be removed by tipping the treadmill over, or pulling the console towards the rear of the machine.
Next, remove the side rails. This is a little tricky because of the cushion adjusters on each side of the deck. If you look underneath the deck, you will see that the adjusters are on rails that are attached to the platform. Remove all of the screws from the side rail and push it toward the rear of the machine while also moving the adjusters rearward. You'll have to kind of move them together until the adjuster slides off the rail. Do both sides.
Remove the rear roller, by loosening the bolts. Don't mess with the front roller unless you intend to replace the motor belt. You don't need to remove the front roller or the walking belt.
There are 4 bolts holding the deck to the frame. The rear ones go through the frame to a lock nut. The front bolts screw into the isolators. Remove them and the deck will come loose. You can slide it out from the walking belt.
Place the new deck next to the old, and start moving the parts over. Make sure the safety decal is on the bottom like the old deck. All of the holes are pre-drilled except for the belt guides. You'll have to measure for these. Now do everything in reverse to reassemble the machine. I'm also attaching instructions on how to adjust the belt.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
Good Luck!
Posted on Mar 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
Posted on May 18, 2010
maxtreadmill
  • 832 Answers
SOURCE: Trying to get replacement walking board for the
Go to iconservice.com click parts replacement input your model then on key# 44 the walking platform is their.
Posted on Jul 16, 2010
  • 103 Answers
SOURCE: need a manual for a nordic track elliptical cxt
Go here...free manual for downloading a pdf file.
http://www.iconservice.com/CustomerService/manualsProductList.do?manufacturer=&model=29864&modelName=&language=&x=0&y=0
Posted on Jul 27, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
I have nordic track 990. Was walking on tredmil felt like it was hestitating now the belt wont move
the belt has two rollers the front one has a motor roller adjustment screw like the one on a car alternator; tighten this screw untill the rolller grips the belt.
Jan 11, 2018 | Nordic Track Exercise & Fitness
My Nordic track 1500 motor will not run, everything else still works????
Step 1:
1) test the input voltage motor,if there are the motor need repair,see the diagram attached, and see my personal TIPS for motor help
Step 2:
tes the output voltage board, for input voltage motor, if there are NOT the board is faulty, replace see the block d.
God bless you
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
Nordic track X9i controls not responding
Dear Sir:
Adjust the reed switch, see the diagram attached, clean, and tight the connector very well.
Anyway I recommend to call the service Help, in the place where you did buy your treadmill.
However you can RUn THE SOFTWARE calibratin for diagnose, troubleshootin, and fix it, follow the steps in your instructions manual.
sincerely. God bless you
May 07, 2012 | Nordic Track Incline Trainer X9i...
My nordic track 2500R incline will not work. The console indicates the level is going up but thing happens. I took the motor to a shop and it works fine. I bought a multimeter and checked out the power...
Dear Sir:
Different things:
1) not any signal from the console 2) Possible damaged cable 3) console has failed. 4)motor control board may have failed from a worn treadmill belt and deck 5) the motor burnt out. 6)potentiometer geared to the motor . These can fail or the gearing can slip, giving the console false information
RUN THE CALIBRATION SOFTWARE SEE THE INSTRUCTION UNDER THE HOOD MOTOR, and follow the steps for easy diagnose and troubleshooting., See my Design from block diagram that will help you to troubleshooting. sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Feb 15, 2012 | Exercise & Fitness
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
May 17, 2010 | Nordic Track Exercise & Fitness
I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Jan 18, 2010 | Exercise & Fitness
My Nordic track 1000 runs great for about 25 minutes then the belt stops working. The display is working. I have to use the stop button and wait a minute to restart the track. Then it will only run for a...
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt.
Nov 09, 2009 | Nordic Track Exercise & Fitness
Apr 18, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Nordictrack 2500 R Treadmill Drive Motor Logo
51 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
