Question about Dryers
Red light on Harbor Breeze remote stays on
After changing the battery in the remote control, the red light stays on.
  • 17 Answers
SOURCE: Remote control for Aloha Breeze fan`
Just give them a call at 1-800-295-4448 with your model number handy. They would be more than happy to send you a replacement.
Posted on Feb 20, 2008
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Posted on Nov 25, 2008
  • 37 Answers
SOURCE: Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Posted on Jan 24, 2009
  • 10 Answers
SOURCE: Remote fans quit working during a thunderstorm-lots of lightning
I've been having the same problem with my remote not working. I actually just checked the dipswitches in the remote against the ones in the ceiling fan, and they somehow were not the same. It seems that the 4th dipswitch may have inadvertently been altered due to the battery either being changed or just moving. I advise you all check out the settings on the actual fan to see whether or not they match up.
Twist the cap covering the wiring above the fan (make sure the power is off, just in case), and you will see a black box like thing straddled towards the top. There is a little rubber square cap guarding the dipswitches. Take that off and note the setting of the 4 switches (on/off). Compare it with the remote by taking the batter pack off and looking at the 4 switches there.
I noticed that the 4th switch on my remote was turned on when it should have been off. I changed it back, and now it works.
Hopefully this helps you all.
Posted on Jun 15, 2009
kingbrizzle
  • 407 Answers
SOURCE: I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
Posted on Dec 31, 2009
I have a Harbor Breeze White 3-Speed Combination Fan and Light Control (Model #: WC-100L) that has stopped working. The red power light does not even light when I push the buttons. Any idea on...
First of all, you bought a cheap store brand fan! The red light is a battery indicator light, so check your battery. If that doesn't work, then you probably need a new transmitter or receiver or both.
Oct 17, 2013 | Dryers
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Harbor breeze ceiling fan remote does not work
You need a new receiver. Harbor Breeze is a store brand made with low-end parts.If you want airflow you need to get a fan with at least a 13 degree blade pitch. Remember you get what you pay for.
Jul 07, 2013 | Dryers
Don't know how to program Harbor Breeze remote
Harbor Breeze remotes are pre-programmed.
Apr 28, 2013 | Televison & Video
Set up remote on harbor breeze
Check the frequency on the receiver & transmitter to make sure they match.
Mar 29, 2013 | Hunter 52" Ceiling Fan With Light And...
Need manual for harbor breeze fan model # LP8063
The remote went bad, this is very common. These are great fans with poor design and cheap remotes. Go to Lowe's buy the new kit ( model: RCE-103LW) $30 bat included. Put battery in and turn off light switch. Have a bic pen ready with the battery cover off. Turn on light switch and press "learn" red button with the pen . You will have to hold it down for about 5 secs. The fan will the turn on medium if it took to learning the new remote. All buttons should now work normal. Return old remote to store for exchange they have a 1year return to to store warenty per the company rep. Anyother problems call 1 800 527 1292. They have good cust. Service.
Jul 21, 2012 | Dryers
My Harbor Breeze remote control fan no longer responds to my remote controller. The first sign of problems was when the lights began flickering momentarily when I tried to dim them. Then the lights went...
this black box is a watt governor for the lights. just remove it, and wire direct. then you should be fine, just let me know the outcome!! the box should have vent slots in it. part # for hunter fan. i do not know if its the same as harbor breeze. --- part # 98480-02, this is what makes lights flicker. if need be replace remote. go to www.harborfans.com and click on support to find phone number for assistance. have a good day !!
Dec 15, 2010 | Dryers
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
Dryers Logo
1,079 people viewed this question
Top Dryers Experts
