I brought my Panasonic TX-P46S10E tv from Switzerland to USA, but when I want to change the country there is no option for USA just European union countries. Will the TV work in the US or must I buy a new one?
  • Johannes Prinsloo Nov 05, 2012
    Thanks Tony, it is a duel system, I have the converter but no signal when plugged intothe tv wall socket
  • 127 Answers
You can use it as computer monitor if you have a converter 220/110
or AC Voltage input switch.There is two systems for the broacasting Pall/Secam
With different frequencies,unless is a dual system will not work.You should buy a New Tv in the USA.
Posted on Nov 04, 2012
  • 4 more comments
  • Tony Nov 05, 2012
    Can you please check the Ac voltage of the converter & How many watts?
  • Tony Nov 05, 2012
    Should read between 110/120 Volts, How many amps compare with Tv.
  • Tony Nov 05, 2012
    You need to now how many amps& watts yourTV needs in order to funtion
  • Tony Nov 05, 2012
    It's in the owners manual specification.Output from the converter has to be Higher
    The TV has power we play movies through our US CD player it is the TV signal through the cables that is not working.
  • Tony Nov 05, 2012
    Follow the owner instructions.Or call the manufacture technical help.
djchillsnyc
  • 152 Answers
SOURCE: Use US Panasonic TV in the UK?
hello, you will need the power step down transformer. i understand the voltage supply in uk are at 220v here it is 120v
they have an adapter for the plug and hopefully you can find the tranformer for it. then you should be able to use it ..
happy holidays and best of luck to you.
Posted on Dec 18, 2008
  • 53 Answers
SOURCE: panasonic lx-32lxd70 lcd tv not working in cyprus?!?!?!
Under the channel setup menu there should be a way to change the input type of the channel. When you go to edit a channel look for this setting. If all your channels are grainy this is probably the solution also.
Posted on Jun 15, 2009
  • 1341 Answers
SOURCE: south american tv not working in australia. can i
110v is used in the mains in the US,what about Australia?Is it 110 or 240v? Also you need to check the frequency and if it is suitable for Australia..Say secam,pay etc..
Posted on Sep 05, 2009
Testimonial: "it works no problem just won't tune in, picture is fuzzy and no sound, has found all channels just not watchable"
ginko
  • 19396 Answers
SOURCE: philips 42PF9630A 42 In
Hi.
The TV can be used in Asian countries, just ensure that TV PAL or NTSC setting is matching the standard in the country of usage.
Here the replacement remote:
Philips 42PF9630A Replacement Remote Control.
Regards.
Posted on May 12, 2010
SOURCE: changing country selection for lcd tvs
Mine has just done the same thing. I'd be interested in an answer as well.
Posted on Aug 19, 2010
I have a Panasonic TX-48CX400B and can't find the pip button how do I get split screen off tv.
The PIP mode is only used to show the current source if you are also looking at the Internet portal mode. After you set up your network connection, press the Internet button on the remote to access the network options. (That's the button with the globe and an arrow that curves up from the bottom right of the globe.) Press OK to select an internet option.
See page 28 of the manual for more information. (I found the manual for the TX-48CX400E here, http://www.panasonic.com/uk/support.html , and looking through the list of LCD TV models. Then click on the Downloads link and then choose the version of the manual you want. From here, you need to accept the Panasonic terms of use for their downloads. The direct link to the manual is http://tda.panasonic-europe-service.com/docs/2z56564c5ez3z3bebbz656ez706466z23zba9e6b6cadec0298b6a49aa5ad340d60c1bb0f19/pgrp001/pcat033/tx48cx400e/933026/BG1WLCAKK3RR.pdf . This is the same model sold in another country.)
I hope this helps.
Nov 25, 2015 | Panasonic Televison & Video
I brought my TX-L32E3E over from Switzerland. I triued to set it up, but it always says that he can't find any channels, even though the previous TV worked on this antenna. Do I have to change
It used to be that the (standard definition) television transmissions in Europe were different than the standard used in the U.S. Actually, Germany used a different standard (PAL) than France (SECAM). Neither of these standards was compatible with the television standard used in the U.S. (NTSC). I expect that the same is true with digital standard used today. You must check with the manufacturer of your TV to see if it is compatible with U.S. TV transmissions. There would have to be a menu item for you to set, or worse, hardware or software in the TV would have to be changed to make it work.
Oct 29, 2014 | Televison & Video
How do I change my country on Panasonic st30b
Go to the settings button and click on the country button there's your answer
Oct 17, 2014 | Panasonic Viera TX-P50ST30B 50AA€A 3D...
Do an Samsung Seek M350, require a sims card.
This is a CDMA (Sprint and many others) network phone, so it does not use a SIM card. SIM cards are used with phones that operate on a GSM network (AT&T, T-Mobile to name a few). GSM is the more dominate network and is used in most other countries like the European Union and the far east. CDM is most the USA and Canada
Sep 20, 2011 | Cell Phones
HI, just brought a Panasonic TX-P50U30E but HAVING PROBLEMS GETTING THE SA\ME CHA\NNELS I USED TO HAVE ON MY OLD TV ! i live in Gibraltar
Sounds like your auto programming needs to be set there should be a option in your menu to scan available channels and even add them manually. I must ask are you getting cable service thru a box or strait thru coax?
Sep 05, 2011 | Panasonic Televison & Video
Dell Desktop brought from Switzerland to USA.
Generally you just need to have a US plug instead of a Swiss plug on hand. Most PC power supplies have a red switch on the back that allows you to use 115 or 230 volt power. If there is one, switch it from 230 to 115 and plug in your computer.
Hope it helps!
Jul 13, 2010 | Dell Computers & Internet
Will the TV work in Australia?
No,if this tv was purchase in the US,Mexico or Canada,because it used NTSC signal frequencies.If u buy it belong in European Union it work fine all European Union work on PAL signal frequencies.Ride a Kankaroo for me,never had a chance was there before.
Jul 12, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Re-configuring for european ink cartridges
i had thed same problem. after hours of trying different options i finally got it to work. i have a hp 3210 that i brought from the usa to irelnad and when i put in irish cartrtidges it said " this printer is cinfigured to use 02 cartridges" Iriss cartridges are 363. so what i done was , while the printer was turned on i held down the " Black" button and the "Color" button at the same time. Keeping them held I powered off the printer , keeping them held until the printer was completely powered off. when i turned the printer back on the region had being reset and it asked me to choose my language and country. chose " Ireland". Now works!!!
Apr 25, 2009 | HP Photosmart 3210 Printer
How to get older panasonic tv working in New Zealand
You will need to have a tuner fitted which will work with the local frequencies. Is New Zealnd NTSC?
Jan 30, 2008 | Panasonic TX-32PL10 32" TV
Aspect ratio makes no difference
Can you go into menu and turn off autoformat?
Oct 08, 2007 | Panasonic TX-32PK1 TV
Open Questions:
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
