Question about Kenmore 24032\24036 Top Load Washer
Washer wont drain
I have a Kenmore 80 series type 111 series # 100 22892 100. It will run but will not drain. The Lid switch has a tooth brush wired to it to keep it out of the water. I suppose it needs a new lid switch from reading other forums where do I find one? Maybe also a wiring harness instead of a toothbrush? It shocked me for the first time yesterday. should I scoop the water out before removing the console?
  • jana moore Jan 04, 2009
    I typed the wrong series # it is 110 22892 100. the console came off like a dream. I found a lid switch part# 62889 on sears web store.is that the one?
I FIXED IT! It was the lid switch for some reason the previous owner had wired it to a toothbrush. I took the switch apart and replaced the spring inside which was rusted to hell. Wired the thing back together so the washer always thinks it is on. Four hours... Three twisty ties,,,, no $ ..... SUCCESS! Thanks for the help!
Posted on Jan 05, 2009
  • 198 Answers
Go to sears web site and enter model number of machine and look for lid switch. The cabinet of the machine needs to be removed to replace this switch. Go to Appliance Guru for details of removing the cabinet
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Wont drain or spin
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it useing the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down .if you have to replace the lid switch for it to work properly or bypass the lid switch it needs to be from under the console .do not drop screws in between the tubs
Aug 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
Kenmore 80 series washer. model #110.29812890. Water wont drain out. Wont spin either. Please help me. I'm so frustrated.
This would be a lid switch i carry them in stock and can ship out today yet... whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Washing Machines
Series 80 kenmore washer, agitates but won't drain or spin
Hi, There is a good chance the lid switch is going bad. When in the spin cycle, does the motor run at all? If the motor does notrun, you will need to test the lid switch first.
Please get me a model# so I can look this model up.
Thanks
Vic
Jun 13, 2009 | Kenmore 22422 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
201 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
