Question about Whirlpool RF378 Electric Kitchen Range
Element Glows Red, can not regulate heat
My stove element on one of the burners just wnt south and glows red hot and I can not regulate the heat on this pone burner. Any suggestions?
  • 530 Answers
You have a bad gas valve For that one specific burner. The valve is located right behing the selecter knob. You have to take all the knobs off and removve that plate to access them. You will see a switch. Remove the switch and right there is your valve. You need to turn both power and gas off when doing this repair.
Posted on Jan 07, 2009
  • erica graber Feb 09, 2009
    i am sorry you have an electric stove and the surface burner will not go to a low setting? if this is the case you have a bad thermistate. you have different thermistates for each burner remove the consol and replace the thermistate
Should the lower oven heating element heat all the way around? The heating element in my oven only heats and glows red on the front and two sides, The rear part of the element never glows red.
This is probably normal. the element has a fine wire inside the tube that you see and depending on where it starts in the tube it will start glowing from there.
Nov 15, 2014 | Maytag MER6872BAS Gemini Electric Kitchen...
Broiler will not come on when baking
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Jan 10, 2013 | Moffat Ovens
Should the heating element on my oven be entirely red ? 80 % turns red right now.
it sounds like the heating element you bought is damaged or burnt out.
return it for an exchange
May 03, 2012 | Jenn-Air Ovens
Refigeration line in freezer gets so hot it glows red.
Thats your defrost element :) If you are not having any problems with your freezer staying frozen, that is normal
Mar 25, 2011 | Microwave Ovens
The right front burner will not get hot. It is only warm never hot. The burner doesn't turn bright red even when tuned up on high.
hello, try changing that front element(burner)if its easily removable to another side that is working normal. If the element is still dull not heating or glowing normal then replace the element, but if it does, then there is something wrong with the front right element switch or the receptacle.
Oct 30, 2010 | KitchenAid Kitchen Ranges
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
Feb 05, 2010 | Ovens
Oven won't work
that apart that glows red hot is probably bad, most likely bad. it should glow white hot and ignite the oven in under 1 min form time it starts glowing, part number 12400035 should help you out comes with everything you need, including instructions
Nov 25, 2008 | Tappan Kitchen Ranges
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Whirlpool RF378 Electric Kitchen Range Logo
180 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
