I need a manual for silver reed typewriter
I have a green manual typewriter approx 1985, in a black plastic case with 2 black push closures by handle.
  • kimmfennell
    kimmfennell Nov 06, 2012
    just to clarify, this is a Seiko Silver Reed 500, manual typewriter
  • 99 Answers
SOURCE: RIBBON CHANGE
Make sure the ribbon is facing the correct side. Usually, there is a small encave which is to be facing downwards. Snap it in place and you are good to go.
Zabrina
Posted on Feb 07, 2008
  • 3594 Answers
SOURCE: silver-reed 500 stuck spacebar
Gently pry a couple of keys above the space bar and look for for forgien objects under the space bar.
DickyO
Posted on Jan 21, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: HAVE AN OLD OLYMPIA MANUAL TYPEWRITER WITH SPOOL
You might try the office places (Office Depot, Staples, etc.). There are also online sources for ribbons. Here's one that came from a Google search for "typewriter ribbons". There were a few more, but this one had nice pictures.
Good luck with the hunt! Thanks for using Fixya.
Posted on Feb 13, 2010
chuckt528
  • 73 Answers
SOURCE: I have a portable Royal typewriter in a black case
Without a model or serial number I can't be sure, but if it is from the 50s it really doesn't have any "antique" value yet. Take care of it though.
Posted on Jan 24, 2011
  • 300 Answers
SOURCE: I need an instruction book for a Silver-Reed EX42
In order to set the margins do this:
1. Using the backspace key, position the carrier on the exact point where the LEFT margin is to be.
If the LEFT margin is set before that point, just presss the MR (margin release) key once and continue backspacing.
2. Now press the Margin Left key once. (You may hear a short beep.)
3. Next, using the SPACEBAR, move the carrier to the right and position it where you want the RIGHT MARGIN, and press the Margin Right once. (You may hear a short beep.)
If the RIGHT margin is set before that point, just presss the MR (margin release) key once and continue with the SPACEBAR.
Now you can check by using the RETURN key to get to the left, and the TAB or SPACEBAR to get to the right.
Getting a User Manual may prove to be a challenge.
Posted on May 31, 2011
Cover removal Silver Reed SR 280 Typewriter
download your owner manual and go to the section assembling and disassembly the treadmills, and proceed according with the disassemby .
www.fitness.manualsonline.com
God bless you
Feb 07, 2013 | Exercise & Fitness
Door handle of my Amana freezer drawer fell off on one side. Screw is inside the handle. How do I fix? AMANA ABL2227FESThanks
It looks like the silver handle is pushed onto the black plastic insert, which must be removed from the handle, fixed to the door and then the handle reattached.
Feb 07, 2013 | Freezers
Need instruction manual for Silver Reed EX43 typewriter
Hello... here is your solution .. be blessed and take care...
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CDUQFjAD&url=http%3A%2F%2Fwww.itsupply.ca%2FKorectype%2FKorectype.pdf&rct=j&q=Silver%20Reed%20EX%2043%20typewriter%20pdf&ei=M5L3TPGeEoT7lwf01v2PAg&usg=AFQjCNHtAFFBFly2gWcRFMC2J_HzNjiZRw&sig2=0pXbH8Vnwslh3MwP3cHaPA&cad=rja
Dec 02, 2010 | Office Equipment & Supplies
Silver reed keeps beeping we need the key strokes to stop it
Go to brother.com click on support you will find a manual there with pictures.
DickyO
Apr 09, 2010 | Brother WP-1700MDS Typewriter
My Singer 507 sewing machine keeps on jamming up, the thread gets wound around the bobin and jams. I have thread the machine as in the manual. PLEASE, PLEASE could you help.
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Apr 05, 2010 | Singer 5070 Mechanical Sewing Machine
Silver-reed 500 stuck spacebar
DickyO
Jan 21, 2010 | Office Equipment & Supplies
HOW DO I install new memory in acer aspire L320
First step would be to lookup your system specs either in your manual or at the Acer website. See what RAM is compatible with your system. Once this is done purchase what you need. Open the case and you should see the RAM modules & slots. If you are replacing RAM you will need to remove the old first. If you are adding to empty slots just line it up properly and seat it in the open slots. Close the case and reboot. System should automatically recognize the new specs. Make sure you disconnect power and properly ground yourself before touching anything inside your case. Hope this helps.
Oct 16, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Typewriter just beeps
very common problem, The print wheel homing sensore weirs broke off. you need to take off the ribbon deck. pull weirs from the white plastic sleeve that runs from carrier to main board. fined 3 weirs grouped together ( red, black,green) 1 or more of them are cracked in side the casing or have broke in 1/2. need to resolder them together little tough to do the 1st time. a bunch of sen sores came out with to hard of a weir making them brake premacherly
Jan 08, 2009 | Nakajima AE-710 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Problems
The right side of the platen has prabably come unlatched. Just push down on the right side of the platen, (black roller the opaper goes around) it should clunk down into place.
Oct 30, 2008 | Lexmark Wheelwriter 15 Series II...
49 people viewed this question
k24674
jasbo
jasbo
