Question about Grinders
Need belt for bench grinder belt #lb-12 - Grinders
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
To find the correct belt you will need to know the Brand and Model Number. Is the number on your old belt or on the grinder? Once you have the correct info you can get parts list by google searing for that. here is what I got just using the bench grinder belt #lb-12.
Just cut and paste the link in a new browser window.
https://www.google.com/search?q=bench+grinder+belt+%23lb-12&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Hope this helps..
Posted on Nov 04, 2012
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
Sep 29, 2017 | Bench Grinders
I have a Ryobi bench grinder and the grinding belt keeps slipping to one side have tightened to maximum and the belt says its for a Ryobi
it is slipping to one side because the pulley on the end is not aligned correctly
on the adjuster arm that holds the front pulley there is a lever or knob that you use to adjust alignment ( instructions in user manual) find that adjustment and slowly move it while the belt is running
you will see the belt running position change to you get it properly aligned
each belt regardless of ryobi or generic will need adjustment after fitting
Nov 27, 2016 | Bench Grinders
NEED BELT FOR OLDER BENCH GRINDER BELT # LB-12
Take the measurement to a auto parts store and they can sell you an appropriate belt.
Nov 04, 2012 | Craftsman Grinders
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Nov 09, 2010 | Wilton Variable Speed Wheel Grinder, Bench...
Runs slow after new brushes dw402 type 2 grinder
I`m not quite sure of what you mean but if the brushes were not seated right it mite slow it down or you mite have a stretched drive belt. I hope this does trick.
Aug 01, 2010 | Craftsman 6" Bench Grinder with Lamp
I have an Abbott & Ashby 200mm Industrial Bench Grinder - CS-8GCM I need to change the sanding belt and am unsure how to do it, can you help?
Remove/open cover on the right side of belt assembly housing. push downward on tracking knob left side top of unit.Belt is spring tensioned to remove slack.Push down remove old belt,push down again for new belt.With belt running adjust belt track(centering) by turning knob,top of unit,toward or away from you,Arrow on inside of new belt governs direction of rotation of belt.
Jun 09, 2010 | Sander 6" Bench Grinder 2" Belt Combo...
I have an old 2 piece bench grinder that was wor...
Could be a belt tension issue. Try tensioning the belt by moving the motor and wheels farther apart by reanchoring the units,or,spanning the gap between units with a series of wood blocks and shims(wedges).Be careful with tensioning. Always manualy move the belt,unit unplugged. There should be some deflection(play) in the belt when pressed upon with a finger.
May 20, 2010 | Grinders
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
Ryobi Bench Grinder with Linisher tracking difficulty.
It sounds like the pulley is not adjusted correctly. This is causing the belt to move on you. Carefully inspect and adjust the pulley so it is square and flat. Use a straight edge.
Jun 25, 2009 | Grinders
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Grinders Logo
109 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
