Xero cxp3535: not printing
I have s strange thing going on with a Creo CXP3535: 1) Creo v2.0 server boots up succesfully, creo sees the printer correctly 2) A simple page copy on the DC3535 (which is connected to the CXP3535) copies succesfully > this does seem to prove that the printer itself is correct? 3) Problem: when i spool any page from the creo (even a test page print from the creo server itself) it displays as "printing" on the creo itself, the printer starts to make some noise (like just before paper pickup of a normal print), but does this without end, not producing any page whatsoever, nor does the creo or dc display any errors... Anybody any clue what could be wrong with my setup? I'm sortoff stunned with this problem...
4 Suggested Answers
  • 164 Answers
SOURCE: Canon Pixma MP750 prints blank pages but prints correct test page
Start by making sure your ink cartridges are full and the correct or recommended crtridges. If ok try routine maintenance by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
Posted on Mar 07, 2010
ericmatienzo
  • 104 Answers
SOURCE: My Epson wont print from my MAC computer but it
Maybe its just the connections. check your usb cable if connected properly. or try to use the printer in windows environment to make sure that your printer is ok.
when i searched the epson database for rx580, there is no model like that. Its epson stylus 580
for drivers
http://www.epson.com.ph/epson_philippines/support/eol_product.page?support_name=Epson_Stylus_Color_580
thanks.
eric
Posted on Oct 29, 2010
  • 669 Answers
SOURCE: my printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Posted on Feb 13, 2012
I have Darwin Desktop 7.0 for Quark Xpress on the Mac. My dongle burnt out. I need a new dongle or a license key that doesn't require a dongle. Can you help?
Hello, Bob.
I'd suggest contacting CREO (from their site):
Send in your dongle serial number and request a licence key number for the Darwin version you want. For further information on obtaining the license key number, write to Darwin.Info@creo.com or see www.creo.com/Darwin
Hope this helps.
Jun 28, 2011 | Computers & Internet
I have konica minolta bizhub pro c500 machine, that is password protected, I don't know the password. how can i reset password?
You dont specify what you want the password to. So here are some options to try.
If you want admin access to the Fiery print controller the default password is "Fiery.1"
The default operator password for a Creo server is "colorserver"
I'm not positive about the default admin password for the C500 but I'd try these.
eight zeros: "00000000"
or: "12345678"
If these don't work chances are someone has changed them from the default. On the Fiery or Creo this usually means a software reload. On the machine a service rep can probably reset the admin password.
Aug 29, 2010 | Computers & Internet
Creo eversmart supreme Mrk 1 solid red status light
There's either a problem with the power supply or the control board, most likely the control board. Have you tried running the diagnostics yet?
-Ryan
omnicow at gmail dot com
Dec 01, 2009 | Creo Office Equipment & Supplies
Tengo un canon mp140 y me pone e4 y e5.creo che
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-12
Apr 26, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
k24674
jasbo
jasbo
