Question about Gateway Computers & Internet
Tje cd rom isn't working properly
The cd rom will not stay closed on my notebook. it reads the disc but will not let me access the material. once i use the cd rom it just keeps popping open. it does stay closed for a short period of time if i shut down my notebook.
    President:
  • 2,110 Answers
Your cd rom motor needs to be replaced..so it is better to take it to nearest service center...
Posted on Jan 04, 2009
I have a notebook 4520G and a couple of days ago after finally sorting out the problems with the graphics card I now find that the drive for the CD rom has totally disappeared. When I inset a disc the...
Hello there is no problem with the driver of your CD rom the problem is in your CD rom. Try to clean your cd rom with a piece of clean cotton. Gentle rub the cotton on the lens of your CD rom, then try to insert a cd if the problem is still there clean it again and again. If does not get by cleaning it is good to be checked by a electronic technician because maybe the lens have a problem or may need an adjustment to the lens of your CD ROm. In ejecting your cd rom there is a problem with your cd rom microswitch which is located inside your CD rom or the trigger of the microswitch is miss align. Hope this can help..
Jul 17, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Hp CD\DVD rom not reading CDs, but is reading DVDs?
cd/dvd rom is probably not working ,try using a lense cleaner disc if that doesn't work it's cheap enough to just install a new drive DVD/Rw as they are about £20.00 new.
Jul 30, 2009 | HP Computers & Internet
CD ROM does not recognize that a disc is inserted -Dimension 2400
i think your cd rom is damaged. you can clean the cd rom lanse or you can buy a new cd rom or your cd is damaged.
Jan 28, 2009 | Dell Dimension 2400 PC Desktop
SGI O2 CD-ROM drive tray repeatedly opens
I am having the same problem. I haven't resolved it entirely, but at least I managed to get it working again by the following steps.
First, disassemble the part of the computer chassis around the CD-ROM drive. Follow the instructions for "replacing the CD-ROM drive" in the SGI 02 hardware maintenance manual. It can be done in 10 minutes with a screwdriver.
After you have gained access to the CD-ROM drive itself, take off the top metal cover. Then you will be able to see the tray and the white gears underneath.
In my case, the problem seems to be caused by some misalignment between some wire springs and the white gears. Note when the CD tray closes, the manual eject button (a black plastic rod on the right) should stick out, and the white piece of plastic with a triangular end on the left should push against the front of the CD tray.
Somehow, the gears failed to push the white plastic piece all the way to the edge of the tray, and the CD-ROM drive thinks the tray wasn't fully-closed, and ejects the disc.
To force the drive to read the disc, pull the white plastic piece on the left with the triangular end towards the edge of the tray. (Pull it towards you if you are facing the front of the drive.) You might need to use some force, but I can get the drive to work this way, even though it still "sticks open" half the time.
Good luck, and if you happen to find a better solution, I look forward to hearing it.
Jan 07, 2009 | SGI Silicon Graphics (P-CDR32-EXT) CD-ROM...
HL-DT-ST DVDRAM GSA-4163B
*Tangent* After scouring the web looking for a solution to this problem, and I bet you this must be the case and problem for many an optical drive owner, regardless of brand or function (CD-ROM, DVD ROM, CD Writer, DVD Writer, Combo CD Writer / DVD ROM) but after busting my head trying to find the solution, some clever thinking solved the problem, where published articles on the web did not:
LG DVD Writer (HL-DT-ST DVDRAM GSA-4163B) no longer recognizes discs and no longer burns DVDs or CDs
So you have a DVD burner that, for the longest time, properly burnt discs and aided you in archiving absolutely everything that has ever been important in your life, and now, all of a sudden on a whim, the drive no longer recognizes discs (when placing a disc with data on the tray and closing it, Windows Explorer changes the label of the drive from a DVD-RAM Drive to a CD Drive and any efforts to view the contents of the disc produce the mocking-error message "Please insert a disc into drive X:" Furthermore, in Nero Xpress, Nero Burning Rom or Nero SmartStart, the screen inviting you to set burn speed, set a disc volume label, toggle MultiSession Disc or toggle Finalize Disc has a nice bright lit illuminated "Burn" label button inviting you to proceed, but any attempts to place a blank CD-R / DVD-R, DVD+R, DVD+R DL, whatever, into the disc tray and closing it fades out the "Burn" button and never illuminates it again unless the disc in the drive is ejected. This, of course, is irregardless of the disc access light blinking its friendly green accessing-goodness-message and coming to a stop as if everything was peachy upon first closing the disc tray.)
*Tangent* The few times this had occurred to me in the past (with completely different computers and computer configurations save the same DVD Burner drive) I would often start disabling and enabling drives in Windows Device Manager, and if that didn't work, deleting drive drivers in Windows Device Manager followed by rebooting and auto-reinstalling, and if that didn't work, disabling drives in the system's BIOS, and if that didn't work, fiddling with the power supply power leads and IDE interface ribbon cables and jumper settings (from master to slave to cable select) until finally the damn thing would kick in and start operating again. This time around though, nothing was working out. It had been two days of fiddling and the damn drive would not come back to me. I had even undone all the bindings of my drives in my PC case and tried the unit in other machines with the same result, and also tried it in a true MS-DOS environment using a CD ROM driver and MSCDEX with the same result. What this indicated to me was that, contrary to what many of the articles say online, that the problem is not software based like many would lead you to believe, but rather hardware based.
I read so many suggestions and not one of them sounded reasonable, considering that the drive had given me years and volumes of successful burns prior and I had already miraculously brought it back to life before: I was suggested everything from flashing the drive's CMOS to deleting lines in the system registry (regedit) to deleting and installing new ATAPI drivers to installing VERY suspect and dodgy executables that would miraculously fix things, to using different burn programs, to changing IDE Interface Ribbon Cables to changing entire power supplies, and my most hated suggestion of all, "the drive must be broken, but drive's are cheap these days anyway, just buy a new one." FOOLS! After careful elimination of possible causes, I ruled out anything that was software, operating system, or BIOS-slash-motherboard based. Sadly, unlike my pop, I know next to nothing about electronics, so my last hope was that it was a mechanical problem. Since the drive not being able to access standard discs with data on it was a clear indication of the problem, I booted in a MS-DOS environment using a Windows 98 Boot Disk, complete with CD-ROM support (these little f'ers are trusty when you get into trouble.) I called up the drive letter for my quote-unquote defective DVD Writer, placed the data disc in the drive, closed the tray, ran a simple DIR command and waited for the "device not ready" message. Once that came up (as expected), I ejected the disc tray, walked to my Grand Mother's sewing room, got a good ol sewing pin (no doubt created before the concept of home computers were even fathomable) closed the disc tray once again, ran the DIR command again, but this time, while the disc was trying to be accessed, I pushed the pin into the little emergency tray release hole, forcing the tray to eject just enough to grab onto with my fingernails. I then simply pressed the standard electronic disc eject button again, invoking a close of the tray, and low and behold, the directory contents of the disc came up. I didn't even have to run additional tests, I knew right then and there that the problem was a mechanical one with the closing of the drive (perhaps the gears were no longer coming into the proper position to place the motor hub onto the hole of the disc or the laser eye became stuck in a position that did not favour starting on the first track of the disc...who knows) Bottom line is, the thing now works as it always did, as intended.
QUICK SET OF STEPS TO REPRODUCE:
Pre-Requisits: Authentically pressed data disc that you do not care if it gets damaged (like an old outdated driver disc, AOL access disc, etc.) and a pin long and thin enough to get significant travel into the emergency release eject hole located below the disc tray (safety pins are a good choice, while thumbtacks and nails are not.)
1 - Boot PC with no disc in the troublesome drive
2 - Within operating system environment, open disc tray, place useless data disc on tray BUT DO NOT CLOSE TRAY
3 - Access a read function of the troublesome drive (in MS-DOS, navigate to the drive letter assigned, close tray with disc and type DIR or in Windows, double click My Computer, double click the troublesome drive's letter until the "please insert disc into drive X:" message comes up, and then close the tray with the disc
4 - While the disc is attempting to be accessed, in a straight manner and with pressure, push the pin into the emergency tray release eject hole until the tray pushes out physically
5 - Close the tray by means of the standard electronic eject button on the drive
-Video Game Junkie
Apr 07, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
CD Rom wants to remain in Open position and doesn't read cds
There might be something jamed or lodged in the CD-ROM compartment which would be preventing it to close all the way so it wants to stay open.Hope this helps =)
Feb 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
DVD-ROM
LS-120 SuperDisk drive help The LS120 will not work off a sound card IDE channel. ... If the computer is on, however, does not eject and you are running Windows 9x.
CD-ROM tray not opening See document CH000885 for additional information about why the CD-ROM or other disc tray ejects by itself or does not close.
CD or other disc tray does not close or opens by itself.
Good Luck, read and folow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | Toshiba A15-S1292 Notebook
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
