Question about Dewalt & 2HP Hand Carry Heavy Duty Electric Air Compressor
I have a Dewault D55141 air compressor that runs to 150 lbs of pressure and blows the valve and releases air. I read your reply to same problem about cut out pressure adjustment
I don't have the emglo version. mine just says dewault on it. I have opened up the whole case and got to where the wires connect to the pressure switch, but there are not any screws to adjust on it. Am I missing something? I don't see any set screws anywhere on it to adjust.
  • Ty Coon Nov 04, 2012
    Mine is the Type 5 version
    Here's the link to the manual at dewalts site for version 5 http://servicenet.dewalt.com/Products/Ge...
  • 512 Answers
Looking at your manual, instead of the actual item since I don't have one, I see 312, 329 and 314. It is possible that 312 the switch is shorted causing the pump to run to pop off and beyond. Item 14 is the pop off valve and if the numbers indicate anything, it is a 175 PSI pop off and is going off early. The switch doesn't have any indication of pressure rating.
The screw and bracket that mounts on the switch may be a pressure adjustment but hard to tell remotely.
Some units like this don't have adjustments, they just pump to a predetermined pressure and stop, being determined by the pressure switch and if the switch fails, a pop off will prevent over-pressuring the tank or system.
If you determine that the screw and bracket do not make an adjustable pressure switch, replace the switch with a like on or one that you can adjust in the range you need. Also if the pop off is going off early, replace or if possible, clean it, they can become dirty with rust.
Is possible that the screw fell out of the pressure switch rendering it "broken" until you put it back in....
Posted on Nov 05, 2012
  • Ty Coon Nov 05, 2012
    Thanks. I'll try that and see
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: I have a Dewault D55141
Hello;
150 is your cutout pressure. It's the factory setting and is not a problem. But, It appears you have a pop off (safety) that is set for 125 psi, So, If you want 150 psi, the pop off needs to be adjusted. If you want 125 the the cut out switch needs the adjusting. The setting. More than likely the 125 psi pop off valve is correct and the switch needs to be adjusted down below the pop off pressure. To sdjust the switch, remove the cover of the box the cord comes out of.Adjust using the screw(s). There should be one for cut in and another for cutout pressuressures. The cut in pressure should be 90 psi and the cutout should be at 125 psi.If the pop off valve blows off at 125, It needs either replace or adjusting. It's best to replace it.since the spring inside has lost tension. You will be constantly adjusting it otherwise. Good Luck -Ned_ Take caution not to get your tool or fingers into the electrical in the switch box.
Posted on Apr 16, 2011
My D55141 heavy duty 2gal (7.6L) 150 psi max builds pressure up to around 150 releases pop off valve then keeps running, what causes this problem?
The pressure switch is either out of adjustment or has failed. The compressor should shut off at a much lower pressure than the safety valve (~100 psi)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Air Tools & Compressors
Excessive air pressure buildup that's blowing safety valve and can hear air leaking inside unit.this compressor is only about a year old!thankyou.
Excessive air pressure...if your safety valve is truely popping off, is caused by a bad pressure switch or a loose wire connection at the switch. It's a little odd to be leaking too. There is a couple a possibilities here. The most common spots for leakage is the "tube seal", the aluminum transfer/supply tube, or the outlet air hose. Usually a leak will keep a unit from acheiving full pressure causing the unit ot run continuously. The other common leakage spot is the "check valve" and a leak here usually makes the auto restart (upon using air from the tank, taking pressure below the set lower limit), not work,stalling the motor and popping a breaker. See ereplacementparts for a proper breakdown and identification of parts. Spliting the clamshell is a "pain in the neck" for these little units, but you"ll likely have to do that to find your internal leak. Carefully avoiding electrically exposed parts, spray a soapy water solution at suspected joints if the leak is not obvious.
Oct 20, 2012 | Dewalt D55141 Oil-Free Hand Carry...
D55141 Electric 2 gallon Dewalt Emglo compressor won't shut off. It builds pressure past the max rating 150 psi and blows the intended safety feature, pressure relief valve as it should, but then...
Hi
your pressure switch is bad. so it isnt cutting off the compressor. the part number is N003306SV and can be obtained from Dewalt on Servicenet.
Detail
Good luck and hope this helps
Oct 26, 2011 | Dewalt D55141 Heavy Duty 2 Gal, 150 Psi...
I have a Dewault D55141 air compressor that runs to 150 lbs of pressure and blows the valve and releases air. I bought it new about 2 yrs ago? What needs to be done with this problem? I noticed on this...
Hello;
Apr 15, 2011 | Dewalt & 2HP Hand Carry Heavy Duty...
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Drops compressiom from 120-60 psi after 3 new pressure switches
When the pressure switch fails the comperssor will overpressure to the point of safety release at about 150 - 160 psi. It sounds as if your compressor is not producing enough pressure to cycle off at 120 and just keeps running. This happens when air is leaking from fittings or worn cylinder / reed valves. Don't worry, with some simple tests we will find the actual problem. I am assuming that your compressor is oilfree type. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve (remove plastic covers to get to all parts that may leak) while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (in your case 60 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating /scratched and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly aligned and that the lip on the vinyl ring is up toward the head. On oilfree compressors you can examine the cylinder by pushing the piston all the way up, then look for scratches neer top of cylinder. If scratched, pressure is leaking past cylinder, install cylinder kit. If you do not feel suction but rather air blowing out of the intake, (do this test when tank has reached 60 psi) then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not be bent or have obstruction. Replace as necessary. If reeds or headgasket is leaking the discharge air will be very hot. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 50+ lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. (check valve is the brass valve at tank) If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. If you have oil type pump, and no air leaks (soapy water test) suspect reed valves/valve plate. Good luck on your repair and email if you have other question.
May 06, 2009 | Campbell Hausfeld 28 - Gallon Air...
Pressure switch out of adjustment
Before you adjust the perssure switch, make sure that the intank check valve is not leaking pressure back to the pressure switch after it cuts off at 140psi. The check valve should hold pressure at 140psi. Follow the discharge airline to the tank to find the checkvalve (either chrome or brass with large cap). To check for leaking valve, run compressor till shut-off at 140, then unplug the compressor from wall and remove the 1/4 air fitting at the checkvalve and check for leak. If leaking, replace valve and leave the pressure switch at present setting. You should be good to go. Good Luck with your repair and email if you have questions.
Apr 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Dewalt & 2HP Hand Carry Heavy Duty Electric Air Compressor  Logo
247 people viewed this question
Top Dewalt Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Dewalt Plumbing Expert? Answer questions, earn points and help others
