Question about Craftsman Grinders
NEED BELT FOR OLDER BENCH GRINDER BELT # LB-12
  • Craftsman Master
  • 8,404 Answers
Take the measurement to a auto parts store and they can sell you an appropriate belt.
Posted on Nov 05, 2012
  • 2712 Answers
SOURCE: Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Posted on Aug 27, 2008
  • 718 Answers
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Posted on Mar 28, 2009
  • 31 Answers
SOURCE: how do you wier up a bench grinder
I would suggest (just from you saying you dont know wireing that well) you should have someone else do it. But if you are determined white to white black to black(or red) make sure you are grounded and check amp to make sure you have the right breaker. I think you should get someone to help you as electrical fires are #1 on home fires .
I hope I helped
Posted on Dec 30, 2009
  • 172 Answers
SOURCE: Need part numbers to replace eyeshields on Dayton bench grinder
Your grinder is listed on page 3085 of the Grainger catalogue. The part number for the eyeshield is 00281.00 and the number for the lower eyeshield bracket is 00280.00. The right hand upper eyeshield bracket is number 25188.00 and the upper left hand bracket number is 25177.00. All of this can be ordered through Grainger at 1-800-323-0620. Marvin T.
Posted on Jan 13, 2010
Testimonial: "This was very helpful. I have ordered parts from Grainger. Thank You."
rowdy45176
  • 2176 Answers
SOURCE: I am looking for a Dayton Bench Grinder Manual
I would try and call Grainger parts to see if they have one. I know they deal with and sell Dayton equiptment. If no luck let me know and I will try and find another source.
Posted on Mar 25, 2010
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
Sep 29, 2017 | Bench Grinders
How do I operate bench grinder?
A murphy, A bench grinder must be used with a lot of caution and respect while using this equipment, Check the attached links,instruction and guides, Good luck work safe.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
OSH Answers Fact Sheets
Pedestal Bench Grinder Safety
Bench Grinder Basics
Mar 21, 2016 | Bench Grinders
Need belt for bench grinder belt #lb-12
To find the correct belt you will need to know the Brand and Model Number. Is the number on your old belt or on the grinder? Once you have the correct info you can get parts list by google searing for that. here is what I got just using the bench grinder belt #lb-12.
Just cut and paste the link in a new browser window.
https://www.google.com/search?q=bench+grinder+belt+%23lb-12&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Hope this helps..
Nov 04, 2012 | Grinders
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Nov 09, 2010 | Wilton Variable Speed Wheel Grinder, Bench...
Runs slow after new brushes dw402 type 2 grinder
I`m not quite sure of what you mean but if the brushes were not seated right it mite slow it down or you mite have a stretched drive belt. I hope this does trick.
Aug 01, 2010 | Craftsman 6" Bench Grinder with Lamp
I have an Abbott & Ashby 200mm Industrial Bench Grinder - CS-8GCM I need to change the sanding belt and am unsure how to do it, can you help?
Remove/open cover on the right side of belt assembly housing. push downward on tracking knob left side top of unit.Belt is spring tensioned to remove slack.Push down remove old belt,push down again for new belt.With belt running adjust belt track(centering) by turning knob,top of unit,toward or away from you,Arrow on inside of new belt governs direction of rotation of belt.
Jun 09, 2010 | Sander 6" Bench Grinder 2" Belt Combo...
I have an old 2 piece bench grinder that was wor...
Could be a belt tension issue. Try tensioning the belt by moving the motor and wheels farther apart by reanchoring the units,or,spanning the gap between units with a series of wood blocks and shims(wedges).Be careful with tensioning. Always manualy move the belt,unit unplugged. There should be some deflection(play) in the belt when pressed upon with a finger.
May 20, 2010 | Grinders
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
Grinders Logo
Top Craftsman Grinders Experts
Jim London
Jim London
Lawrence Oravetz
Vernon Taylor
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
