Question about Garden
I am not getting gas to the engine on my model 300 yardmachine tiller, what do i do?
THis is a model 300 front tine tiller made by yardmachine/mtd. The model number on the engine is #94212...type 0319 E1. The manual suggests cleaning the fuel line....how do I do that?
  • William Towner Nov 07, 2012
    I should have added that this tiller has a briggs & stratton 3 1/2 hp engine. If I add some gas to the carburator through the choke opening, The engine will start and run until the added gas is gone. I think I am not pulling gas from the gas tank into the carburator. Should I remove the gas tank and clean the intake tube and it's screen. If so, what should I use to clean it with?
2 Suggested Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
I inherited an MTD front tine 5hp rotto-tilleran woner. I have no idea about model number. I have not yet found an owner's manual, operation guide, etc. There is no model or serial number anywhere. ...
What to remember when working on these gas engines you have to have fuel spark and air usually on these small engines there is a screen in the bottom of the gas tank that gets clogged up check out the spark plug and take the air filter off and wash it in warm water with dawn dish detergent let squeeze all the water out of the filter and let it dry out a day or so hope this helps Merry Christmas
Dec 09, 2017 | Mtd Garden Tiller (Mtd)
How to operate sears5 hp rototiller. Especially the gear shift. Has reverse
Hi and welcome to FixYa, I am Kelly.
Find the long model number on your tiller. Then go to this site: http://www.managemylife.com/mmh/owner_manuals
Enter your model number and searh for you manual. When the manual is found click get manual or rt click the manual you want Owner, Engine, or parts and download it. The instructions will be in the manual.
This is an example of a model number: 917295852 and the manual for that rear tine tiller is here:
http://www.managemylife.com/mmh/owner_manuals/86874/CRAFTSMAN-Rear-Tine-Gas-Tiller-1006404L?brand_name_search=917295852
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Mtd Garden
I have a 1996 MTD front tine tiller that was left in someone's shed for about five years. I have emptied the fuel and oil from the tiller and want to rebuild or replace the carburetor and fuel line before...
See if you can find the model number on the engine and then go to the Briggs and Straton web site for the manual for the engine. The tiller manual will not have engine info in it. I hope this helps.
May 31, 2010 | Mtd Products Yard Machines 158CC Tiller
Where is the fuel pump on yardmachine rototiller Model # OHH60
THERE IS NONE ITS A GRAVITY FED CARB, THE CARB NEEDS TO BE CLEANED. IF YOU DO IT YOUR SELF TAKE PICTURES SO YOU CAN REASSEMBLE IT !! THE FLOAT IS STUCK. THATS WHY YOU ARE NOT GETTING GAS.. IF'N I WAS OF HELP PLEASE VOTE..JAY
May 25, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
MANUAL FOR 1994 MTD TILLER
www.ereplacementparts.com/mtd-215412000-1985-tiller-parts-c-20039_20363_20380.htm
Jul 09, 2009 | Garden
Need a manual for yard machine model# 135202
Hello:
A Breakdown should Assist youin Assembling the Tank and Carburetor. If the Engine Breakdown is Not at this Site, then Send me the OEM, Model and Type/Spec Numbers Off the Engine, Please. With these I can Locate the Correct Manuals and Better Assist you.
You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMan_10101_19502_-1 and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers. Then Double Click on the Model in the Results Area. Now you can Select the Section of the Unit you Wish to View.
You can Contact MTD at 1-800-269-6215 at during the following times and Request/Purchase a Manual: Monday-Friday 8am-5pm and Saturday 11am-3pm EST. (SEASONAL HOURS MAY VARY).
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Mtd Products Yard Machines 158CC Tiller
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
