Question about Thomson RCA Home Control X-10 Lamp Module HC10LM
How to find manual or instructions for Lamp Module HC10LM
Need help to understand how to set the module, i.e., instruction manual
How do you use the pattern stitching module in singer model 2732. I have the Manuel but still don't understand how it works. I have followed instructions and nothing happens. I must be doing something...
Have you installed the stitch selector pattern module for the patterns you want, seated it properly as outlined on page 52 of the instruction book following all 7 steps? (Page 54 identifies the knobs and lever's that need to be moved to successfully install the pattern module)
If that is done correctly, then selecting a stitch is done with the stitch selector lever being moved under the letter corresponding to the stitch you are trying to select. (Shown beginning page 55) You also need to move the stitch length knob as indicated.
You will need to be sure you are following the instructions very carefully as there are a number of settings that need to be made to ensure you get the stitch you are trying to achieve.
I hope this helps you.
May 22, 2014 | Singer Sewing Machines
How to set my grasslin pool time trying to understand to let it run in day and shut off at nite about 6pm so i need to set it that way with the pin
Open following link for setting Intermatic/Grasslin FM1 timer setting instructions:
To set the 24-hour analog timer, you need to move 4 consecutive tripper pins for each hour of run time.
So for 6 am to 6 pm, 48 trippers pins will be moved outward and 48 inward.
http://waterheatertimer.org/pdf/How-to-set-Intermatic-FM1-timers.pdf
Open following link for Intermatic FM1 series and PB series modular timers with wiring, manuals, model numbers and instructions for setting.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
I have a samsung hln437n and I have a loud, high pitch buzzing noise which stays on all the time. It sounds like it is coming from the lamp. Any idea what the problem is?
Could be a slightly loose lamp connection and/or slightly loose lamp module - especially if you
have big trucks or railway tracks near your place (like me). Try powering down the TV set, use the
instructions that came with your TV to remove the lamp module, then simply re-install the lamp
module (also known as "reseating the lamp module").
If the buzzing noise persists, then
its coming from a component near the lamp (such as the power supply).
If there's a transformer in the power supply that's buzzing, then its about to fail.
Apr 17, 2011 | Samsung HLN437W 43" Rear Projection HDTV
Edifice casio chronograph user manual
Hi, Since you didn't specify the model or module number of the watch, try this link:
http://world.casio.com/wat/download/en/manual/
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you.  Thanks, Bill
Sep 07, 2010 | Watches
I just purchased a Casio Men's Illuminator watch #AW-80-4BV that came with no instructions. How do I set the clock hands properly and understand the alarm features?
If you go to the following link and put your module # in, you can download instructions for your watch. Hang on to them as you never know when you will need them!
Aug 21, 2010 | Casio Watches
Dash pannel fuel indicator lamp shows empty but tank full
This would be very common of the fuel pump and level module in the tank. The module from auto zone runs about $280. This must be purchased as a module and replaced. The tank then needs to be dropped out of the car to make this repair. Let me know if you need further instructions to complete this.
Jul 24, 2010 | 2003 Cadillac Deville
Please I need to put the clock in hour and I don't understand like one makes
Here is the link to your watch manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2600&submit.x=60&submit.y=11
Save it on your PC and follow instructions how to set an hourly alarm.
Don't forget to rate, please.
Jan 06, 2009 | Casio G-Shock G2600 watch
I have a gold casio wrist watch from urban outfitters and I have accidentally set the alarm. It now goes off everyday and I can't work out how to turn it off! help would be greatly appreciated.
You will most likely need to go to the "Alarm" setting mode to toggle the alarm on or off. On the back of the watch, there should be a number inside a rectangular box. This is the module (not model) name. The module is the "brains" of the watch. If you go to the support section of www.casio.com and look under watches/manuals, you will be able to input the module # and download the instruction manual for your watch as a PDF file.
Aug 12, 2008 | Casio Watches
LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Aug 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Thomson RCA Home Control X-10 Lamp Module HC10LM Logo
Top Thomson Home Security Experts
Lawrence Oravetz
Are you a Thomson Home Security Expert? Answer questions, earn points and help others
