Question about LG 60PG3000 60 in. HD-Ready Plasma TV
LG 60PG3000 60 lines on screen
I have 2 discoloured lines on the left hand side of the screen about 2inches wide each plus a red line between them about 1mm wide
  • 10 Answers
SOURCE: RED LINE GOING VERTICALLY DOWN THE SCREEN
control board
Posted on Jan 29, 2008
Mark_Webber
  • 472 Answers
SOURCE: LG RZ-26LZ50 LCD Television-Solid Black line down the right had side of the screen
It's the driver tabs that operate that section of the panel. To have them repaired/replaced can be very expensive and is normally just replaced completely as a whole panel (at least while under warranty). If it is out of warranty, then get a few quotes over the phone. This will help dramatically when you explain to your wife that you are about ot go shopping to buy a new TV.
I find things like "Have I told you how good you look today" help when this process is taking place.
Sorry for the bad news.
Posted on Apr 12, 2008
SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
Posted on Jun 06, 2008
  • 4 Answers
SOURCE: Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Posted on Jul 17, 2008
SOURCE: LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
http://greenrenovation.wordpress.com/du-42px12xc-repair/
Posted on Feb 04, 2009
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
I have an LG Plasma Model#DT42PY10X. IT HAS A RED LINE RUNNING DOWN THE RIGHT HAND SIDE AND i WOULD LIKE TO KNOW HOW TO FIX THIS PROBLEM. THANKYOU
Hi:
If the line is less then 2 inches wide this us a good indication of a bad PDP panel (Screen) usually very thin lines indicates a failure in the screen itselg, altho you might try replacing the upper and lower buffer boards to ensure its not the screen. You might want to take off the back and try reseating all connectors leading to the buffers and the Digital board. But in my experience thin lines less then 2 inches usually results in a bad PDP.
Jan 30, 2010 | Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Oct 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
LG 60PG3000 60 in. HD-Ready Plasma TV Logo
88 people viewed this question
Computer Repairing
Computer Repairing
