Lexmark 2500 Series Printer Color Ink Cartridge Won't Work Properly
I moved into a new house a few weeks ago and so obviously everything had to be hooked up again, and some things had to undergo updates and such. But yesterday I tried using my printer for the first time. It wanted me to do an alignment test, so I did. When the sheet printed off, the only colors that would come out were red and black, but I have a full color ink cartridge and the tape has been taken off. Any ideas as to what I can do? I've taken both ink cartridges out already and put them back in, et cetera. I have no ideas as to what I should do now.
SOURCE: color cartridge missing
The error 50c
Posted on Jan 15, 2007
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
  • 214 Answers
SOURCE: Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
Posted on Apr 28, 2009
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
  • 104 Answers
SOURCE: Do I NEED 2 ink cartridges on the Lexmark 2500.
Yes you do need 2.
All ink cartridge bays has to be filled with a working cartridge, for the print driver to allow you to print. That is why I prefer single ink type printers, so it is not so expensive to maintain the inks you don't use.
Posted on Mar 10, 2010
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Why won't my Lexmark 5600- 6600 Series Printer print in color?
It could be the print setting on the application where you're printing from. Before you send your print job and hit "Print" button on your computer, check in the Printing Preferences and make sure it is not set to print "Using black ink only.".
Mar 06, 2012 | Lexmark Office Equipment & Supplies
My printer does not acknowledge presence of ink cartridges.will only print in black
It could be that the color cartridge is not seated properly or just needs cleaning.
Try to re-seat your color ink cartridge. Open the printer cover > remove the color cartridge > re-insert the color cartridge and make sure it's properly seated > close the printer cover. Try to print again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z600 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 04, 2012 | Lexmark Z600 InkJet Printer
I have a broken ink cartridge holder on a lexmark 730 series.it is saying ink cartridge missing
Hi David,
Unless you have a very expensive printer or you know of a store that has a wide range of used printers, it won't be worth your time and money to order a new cartridge tray for your printer.
I would suggest buying a new 730 series printer and keeping the old one for spares.
If however you're curious as to the price of a new cartridge holder it would be your best bet to browse to www.lexmark.com and do a parts enquiry from the website.
Best wishes,
Graemevm
Jan 14, 2012 | Lexmark Office Equipment & Supplies
I cannot get my printer open to change cartridge for x4270
Here's a comprehensive guide on How to Install Ink Cartridges in Lexmark X4200 Series All-In-One's.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this information has been helpful.
Aug 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
Installed new 28 and 29 cartridges in lexmark x2550 and it won't recognise the cartridge and won't print at all, very frustrating please help urgently
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 29, 2011 | Lexmark X2550 All-In-One Printer
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    Lexmark z23 cartridge banging
    The encoder strip may have become unseated. please follow the steps given below:
    The embedded links in the table lead to specific troubleshooting steps.
    1 Turn off the printer and disconnect the power cable from the back of the unit.
    2 Open the printer's front cover.
    Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
    3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back.
    4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
    5 Reconnect the power supply and turn the printer back on
    If the issue persists after you have attempted the steps with a new color cartridge, continue to Contacting Lexmark.
    Jan 31, 2009 | Lexmark Z2300 InkJet Printer
    Need to change the ink cartridge on lexmark model #x2350
    1- Turn the printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
    2- Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps 3- Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
    4- Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
    5- Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you’ve completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
    6- Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
    Nov 27, 2008 | Lexmark Office Equipment & Supplies
    Colored Ink problem
    Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
    Jun 08, 2007 | Lexmark Color Z35 InkJet
    103 people viewed this question
    k24674
