Question about Seagate 320GB Portable External Drive Black 320 GB USB 20 Hard Drive
I have a Seagate 320GB external hard drive and it told me it was close to full and the next time it tells me to format it. I want to open it to delete some files to get more memory. how can I open it
My seagate 320gb external hard drive told me it was close to memory full then next time it tells me to format it. How can I open it to delete some files and get more memory?
Alcatrazx
  • 65 Answers
SOURCE: 279GB free space in a Seagate 320GB will not take a 5GB pst file
First of all HI :)
The main problem you have is that the file system of your hard drive is FAT32 not NTFS. You need to change it to NTFS in order to work. Here is how.
>> Copy all your data (the 50+GB you used) on to another hard drive
>> Now from My Computer
>> RIGHT CLICK
>> CHOOSE FORMAT
>> CHOOSE NTFS FILING SYSTEM
>> instead of FAT32 and
>> give your hard drive a nice full FORMAT
This will take a while and WARNING you will LOSE all your DATA so DOUBLE CHECK BEFORE YOU START THAT YOU COPIED EVERYTHING.
Hope that this Fixya Helps you :)
Best Regards
(please take some time to rate solution thanks)
Posted on Jan 07, 2009
SOURCE: How to extact the data off the Seagate Barracuda 7200.10 320GB HD
if its your motherboard that crashed then ther is no problem with your hard disk. connect your hard disk to any other computer and you can access all the files in it.
if it is your harddsik that crashed then try recovery utilities like western digital data storege manger or any other disk recovery tool available for free. if still it fails then you can recover your data if you hand over your hard disk to the nearest service centre. but recover from a hard disk only if its very valuable. thay will charge you per MB of data recovered
Posted on Jul 04, 2009
  • 13433 Answers
SOURCE: I have just installed the Seagate 320GB external
to view the contents of the drive connect it to the computer and make sure both are turned on and that the drive is detected by your computer (you get a ding sound when you connect it)
You should see the drive inside my computer, or computer, which you will find from either your desktop or from start menu.
Look for the drive in my computer, it will possibly be named as a removeable storage device, the contents should be inside.
If its a brand new drive it might need to be partitioned and formatted first before it can be used.
Posted on Aug 14, 2009
bob_computer
  • 3153 Answers
SOURCE: 320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Posted on Sep 17, 2009
josema_sv
  • 500 Answers
SOURCE: my Seagate portable 320gb external
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Posted on Feb 18, 2011
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
Can a Seagate External Hard Drive be reformatted?
Yes you can.
Insert the external hard drive into the USB port click on My Computer then right click on the external hard drive and select Format.
Apr 01, 2013 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
Hi i need to copy files from my macbook to my seagate hard disk which is in ntfs format.. it says it is write protected... help me...
the ntfs format is windows operating system format...
MAC will not recognize this format...
You need to format your hard disk according to the MAC OsX from your MAC computer...
Dec 13, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
Usb broke off my seagate 320gb external
it does'nt really matter IDE or SATA both are using same connector. you can change it from second hand or from another board sometimes its not available.
Sep 02, 2009 | Western Digital 320GB MyBook External USB...
External Hard Drive I/O Error
Somehow i tried to format and it was formatted. took pretty long time as 1 terabyte. i thought all is ok as the drive was accessible. Just to double check, i scanned the drive thorugh the seagate manager and it got stuck on 10% for few seconds and then said that the hard disk is faulty and should be immediately returned if under warranty. and to confirm it also gave me read errors http://www.dtidata.com/resourcecenter/2007/05/15/how-to-tell-hard-drive-physical-damage/
so i'm giving it to seagate service centre as it probably has physical faults, bad sectors. and someone told me that 1TB hard drives are not stable.
Jun 18, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Accidently deleted photo files from a external seagate hard drive. Is there any way to get them back???
I bought PC Beginner from www.PCbeginner.com . It has programs that I have used to recover photos. It has other good utilities on it too. It's a good disk to have.
May 04, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=174395
Jan 24, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
First of all HI :)
>> RIGHT CLICK
>> CHOOSE FORMAT
Best Regards
Jan 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 320GB Portable External Drive  Black 320 GB USB 20 Hard Drive Logo
139 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
