Question about Compaq Presario 5000 PC Desktop
ONLY GETTING LIGHTS AND FAN TO COME ON - Compaq Presario 5000 PC Desktop
    Problem Solver:
  • 15 Answers
If there is no "beeps" probably PSU or MBbut try next... disconect RAM, HDD, optical drive and any PCI devices you have... if here is still no beeps it is what I said, PSU or MB. if it starts beeping put RAM in, if there is no beeping and it wont start then you have a bad RAM. ofcourse anythig you change (disconecting/connecting any PC device, PC must be OFF)
Posted on Nov 04, 2012
Wires getting hot
start with any accessories first than battery/connections and then lights ,cooling fan-and 12v plug and check 4x4 switch and actuator may be hanging up causing a draw
Jul 25, 2016 | Polaris 2006 Sportsman 700 Twin EFI
Coooling fan head lights wipers wont work
The headlamps/wipers are most likely the multifunction switch, on the steering column side. This is a combination switch for the wipers and headlamps. The removal of steering wheel/airbag need to be accomplished. This should be performed by a professional.
There are 2 cooling fans, you need to verify which one, there is a large connector to fan, verify if you are getting power at the fan motor to determine what is the faulty unit. They are relativly easy to change, the fan and motor will come out as an assembly. .
Apr 22, 2014 | 2002 Pontiac Sunfire
No lights on AC unit but fan is running.
Possible that the processor has failed and it seems to give a through circuit to the fan which runs when power is switched on.
You can check the voltage on the processor IC and if absent then you must check the DC voltage on the circuit board. If there is no power then it is the failure of the power supply section and if not the processor is the suspect.
Sep 27, 2013 | Fedders Heating & Cooling
I have a weird problem, the fan remote will only work if the light is turned on; I cannot turn on the fan without having the light on - very frustrating when you want to sleep.
Has this just started happening or has it been going on since the fan/light was set up? If there are two wall switches, one controlling the fan and one controlling the lights and they have recently been installed, seems like the fan is getting its power from the light switch. Please tell me if there are two wall switches controlling the fan and lights and we can go from there.
Sep 19, 2010 | Hunter 20537 / 20538 The Vista Iron...
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Lights and fan belt squeaking
replace light switch..and tighten fan belt GL
Jun 26, 2009 | 1999 Nissan Frontier
1985 VW Jetta Diesel, problem with lights. The
check head lights and tail lights relay.replace fan relay.check ac compressor make sure its getting power. if all good have ac check to make sure it have the right amount refrigerate in system.
May 16, 2009 | 1985 Volkswagen Jetta
New fan not working but lights work
There is less than 120v getting to the fan. Its possible that the lights will turn on etc. Take an extension cord and plug it in another plug and grab both power wires from the fan and stick them in other end of extension and I do service calls for broan & Nutone
Jean-Marc
try it out. Im sure your not getting 120v completelty.
Feb 05, 2008 | Broan-NuTone Allure QS130SS Kitchen Hood
Lights are now dim.......
Aside from a wiring fault upon installation that may be creating a small short, or interference from the fan motor, have you tried fixing the cheap parts? I.E. changing the lightbulbs out for a different set, or different types? Try using flourescent bulbs in place of your normal incandescent bulbs. Also, what wattage are you using? Your fan unit may have a limitation on wattage, or may only be throughputting a certain wattage due to a wiring problem. Does your fan have an energy saver setting?
Aug 19, 2006 | Hampton Bay B52852WPB Redington III White...
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
