Video input 1 and 2 stopped working suddenly after working perfectly fine for months never had this problem
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I suppose you have tried another cable----if just one was bad or acting up I would suspect a broken connection at the in point on the set--leaves just one thing to try------hook same cable and vcr to another set......just to see if set or video unit is problem.
Posted on Nov 04, 2012
  • nickksickk Nov 05, 2012
    The cables weren't the problem I tried my tv in the living room and it works fine in there. It is just odd 1 minute both inputs worked fine then i accidentally hit the power button and when i turned it back on theres only 1 video input option and the picture is grey with no sound. The front panel input (video input 2) can't even be selected anymore!
4 Suggested Answers
  • 4 Answers
SOURCE: sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Posted on Jul 23, 2007
dsacco86
  • 1077 Answers
SOURCE: Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Posted on Feb 17, 2009
  • 8457 Answers
SOURCE: input 1 for hdmi stopped working. Input 2 works
Reset all setting back to factory setting.Unplug,replug,should work,if ur backlight video it good,not any coponnents damages.
Posted on Dec 22, 2009
Projector was working perfectly...suddenly started a constant flickering. Images/text still visible but annoying.
This is most likely a signal issue. Check to see if the issue manifests in all video modes or only in one. If using a computer, look at the analog or DVI video cable for broken or bent pins. More than likely, you'll find the issue is only there when in PC mode, a VCR input works fine.
If this is not the case, then the main board is damaged and you will need to try moving the input to another port. S-Video, RCA cable, or PC2.
Jun 21, 2010 | Optoma EP758 - HDTV Compatible DLP...
Input 1 for hdmi stopped working. Input 2 works
Dec 22, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
Sony DVD Player worked fine forever, suddenly gets 'No Signal' on
check the video is going from output on the dvd player to the input of the tv. Good Luck.
Nov 12, 2009 | Televison & Video
Power window on 1990 Ford F150 stops working
the motor has an armature inside that rotates.if it stops on the bad spot,it will draw alot of current.the armature has copper plates with a very fine separation between them.after a while the brushes wear the copper down and it can bridge 2 together.the motor will still run,until one brush stops right where the 2 plates meet.if you bang on it it will work too sometimes.
Jun 12, 2009 | 1991 Ford F150
My Wireless LAN button has stopped to work
I just reloaded windows XP after cpmplete failure , Lan just seems to be Missing Can not find in device Manager
Dec 24, 2008 | Acer Aspire 5610-4648 Notebook
I own a LG rear projection tv model number RT - 44NZ31RB and for some reason refuses to turn on. Worked fine and then all of a sudden stopped. Standby light comes on and then a small noise can be heard...
had the same problem as described, exactly. happend after 13 months of use.
I had the power suply replaced and it works perfectly since then.
Jun 30, 2008 | Televison & Video
Audio input/output
It sounds very much like your receiver needs repair by Sony.
www.esupport.sony.com
Sep 06, 2007 | Sony STR-DE998 7.1 Channels Receiver
NO Picture On 2 Video Inputs ( 1 front 1 rear ) : Sound OKAY
Since it is 5 years old mostly dry soldered appears. First sort out the soldered problem. Then check zener diode in video input path is short. Mostly the diode is short. Still get problem check video switching ic also. I think former is the most problem.
Dec 13, 2006 | Sony KV-36FS12 36" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
