GRSL3643SM-1 HOW TO SET STOVE CLOCK
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
I can't get my clock set on my GE stove model # JB645DT1BB It said to hold for 3 seconds to change the time but it doesn't change. HELP Please
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing functions
to work properly,The time of day cannot be
changed during a delayed cooking or a delayed
self-cleaning cycle,
1. Touch the Clock pad twice.
For models without a Clock pad:
Hold the + and - pads for 3 seconds.
2. Touch the + or - pads.
If the + or - pads are not touched within one
minute after Step 1, the display reverts to the
original setting. If this happens, repeat Step 1
and reenter the time of day.
3. Touch the Start/On pad until the time of
day shows in the display. This enters the
time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
Clock pad. The time of day shows until another
pad is touched.
http://www.managemylife.com/mmh/owner_manuals/138431/GE-Free-Standing-Electric-1112529L
Sep 19, 2013 | General Electric Stove/Oven/Range Chrome...
I wana fix the time for this stove
tahts should help
http://www.ehow.com/how_7419929_set-digital-stove-clock.html
http://www.youtube.com/watch?v=iQU9Kv2yfvc
http://www.ehow.com/how_8153132_set-clock-kenmore-elite-stove.html
Nov 06, 2012 | Kitchen Ranges
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
Jan 06, 2010 | General Electric Stove/Oven/Range Chrome...
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Clock on Whirlpool Stove
Check to see if the oven is set to timed bake.
Jan 22, 2009 | Whirlpool GR460 Electric Kitchen Range
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Setting Clock on Hotpoint Stove
push in on the center one I think
Mar 10, 2008 | Kitchen Ranges
35 people viewed this question
 Grubhead
Grubhead
