I have a Bush WV 1460TVE washing machines and I have a code showing ERR 5 and stops mid cycle. What does this mean?
  • 47 Answers
This is from the manual...
Err5.... CAUSES/SOLUTIONS: Water level not met in 8 minutes/Make sure that tap is turned on and water pressure is normal.(a)
C/S:Height of the drain hose is below 80 cm/Install drain hose within80-100cm of height. (b)
C/S: The drain hose is in water/make sure the drain hose is not in water. (c)
Posted on Nov 04, 2012
stradeteox
  • 88 Answers
SOURCE: washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Posted on Jan 07, 2009
localwonder
  • 6784 Answers
SOURCE: stop in mid cycle
HD= No drain.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 17, 2009
  • 5 Answers
SOURCE: hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Posted on Sep 17, 2009
  • 156 Answers
SOURCE: My washing machine is flashing
sounds like either the pump is blocked or broken.
bring machine forward so that you can tilt it back so as to be able to undo filter cover.
Be aware, lots (and i mean lots) of water will exit so a) have a big bowl and b) only undo filter cover a little so can retighten quickly.
Repeat until all water gone, remove cover completely and clean pump and filter area.
Refit cover, put machine back on floor, put on spin cycle and if it was a blockage, machine should empty. If not, new pump time I'm afraid
Posted on Dec 08, 2010
Daniel S
  • 4323 Answers
SOURCE: my bush WM-1460TVE washing machine
Hi
The problem seems to be with the door lock-switch assembly that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 08, 2011
Bush washing machine error code 8888 what does this mean
Error code Err 08 The start/pause light, program ready light and program end light blink. The motor has failed. Shut down your machine and unplug. Turn off the tap and contact the nearest authorized service agent immediately. http://electronicshelponline.blogspot.com/
Jul 14, 2016 | Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    AEG Lavamat 11842 Error code E66
    http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
    Feb 23, 2013 | AEG Washing Machines
    Hi my bush WM-1460TVE has been stuck on the same cycle 3.00 minutes for the past half hour it just goes round and round and is full of water still? Help?
    Problem with the program controller unit. Remove the plug and power for some time and try again. If this wont work it is possible that unit has failed.
    Jun 26, 2012 | LG Washing Machines
    What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
    hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
    Its looks pump dont work //////
    Please advise me what to do ???????????
    Thanks
    Mar 19, 2011 | Washing Machines
    My washing machine is flashing err2 and is not spinning. I have lots of clothes locked in a machine full of water! Help! wm-1460tve bush washing machine
    Dec 08, 2010 | Washing Machines
    Washing machine keeps stopping mid cycle
    Nov 20, 2008 | LG WD-1280FHD Front Load Washer
    Washing Machines Logo
    52 people viewed this question
    Top Washing Machines Experts
