Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Pro heat 9500 2X
Brushes won't rotate. Belts are in place, nothing happens. Is there a reset button for the motor, I don't think its running
I had this same problem, even went out and bought a second machine, same problem. Here was my problem....I was checking the brushes while the handle thingie was in the upright position. You have to be sure and RELEASE THE HANDLE. Now i have 2 perfectly good Bissells.
Posted on Jan 26, 2009
Try changing the belts. I ran into the same problem. I changes the belts and it is working again.
Posted on Jan 17, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ... > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Does the bissell pro heat have one or two belts?
The Bissell Model 25A3 has two belts, a pump belt and a brush roll belt. The pump belt (Bissell Part # B2150628) is flat and runs from the motor to the pump. The brush roll belt (Bissell part # B0560621) is cogged and runs from the pump to the brush roll. See key numbers 34 and 36 below.
May 17, 2010 | Bissell 25A3 Upright Vacuum
Brushes will not turn, belts are hooked up
There is a main motor to gear drive belt and a smaller cogged belt to drive the brush/beater bar. There is no reset switch, but make certain the motor is turning the belt and not broken, By using flat head screwdriver,pop the side plastic piece up and off the base unit and visually see what is happening when the power switch (not heater ) is turned on. You say the belts are hooked up?? Meaning that they are tangled?
Apr 26, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I would like to see how to change the belts on the bissell 8910 pro heat I have looked for hours now. I saw the book but it mentions and shows nothing on how to replace them. Help please.
turn the vacuum over so that the bottom side is facing you, remove the 4 screws on each side using a Philips screw drive set the screws and the brush cover aside.
- pull brush straight out and you will see the gray rubber band.
-replace the new drive belt over the motor pulley and the floor brush.
-replace the floor brush by lining up with the slots and rotate untill centered , install the cover and screws . done your back in action.
Hope this helps.
Sep 05, 2009 | Bissell 8910 ProHeat Clear View Upright...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Pro Heat 2x steam cleaner, problems!
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Mar 14, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
288 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
