Question about Fuji FinePix F30 Digital Camera
Fuji finepix f30 overheated and wont switch on
Camera got hot and would not work
5 Suggested Answers
SOURCE: Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Posted on Mar 13, 2009
  • 6 Answers
SOURCE: My Fuji Finepix F30 has a broken shutter button.
Its fairly easily fixed and its a common problem with the F30. The shutter button contact slides off upon impact when dropped, it must be re-aligned so that it makes proper contact and performs normally. All that is needed is the special screw driver for the F30 (easily purchased online, just google it: "screw driver for fuji f30" ) or bring it to your local watch/jewelry repair store and tell them to open it up for you.
We have two F30's and they both have been dropped, both did the same thing with the shutter button. But both were easily fixed. Always keep the camera in a safe place and away from kids, they are very sensitive devices. Use the wrist cord when taking photos.
Posted on Nov 24, 2009
  • 6 Answers
SOURCE: Fuji FinePix F30 shutter problem: won't take pictures
lock123
  • 6831 Answers
SOURCE: fuji finepix f650 zoom lens
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 20, 2010
Camera will charge battery but wont open lens or show a stored photo
Camera wont open lens or show stored photos, ever since i dropped it.
Apr 06, 2010 | Fuji FinePix F30 Digital Camera
Need the time and date to print out on my photos the camera is finepix f30 i have no instructions
Menu screen set the language,date and time then go to your photos on the playback screen =(green arrow) then press F button scroll down to print order (DPOF) select print with date.
Mar 24, 2010 | Fuji FinePix F30 Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Fujifilm Finepix F30 zoom error - what can I do?
Switch the camera off and on again 2 or 3 times.
If this does not clear the error the your device need service (repair)
Have a nice day.
Rating the solution will highly be appreciated.
Mar 05, 2010 | Fuji FinePix S5000 Digital Camera
Nov 19, 2009 | Fuji FinePix F30 Digital Camera
My Fuji Finepix F30 has a broken shutter button. The problem seems mechanical, because it won't work in any mode. Can it be repaired?
Nov 03, 2009 | Fuji FinePix F30 Digital Camera
'Card not initialized'
I just bought a sweet FUJI FinePix S5700...
I could not for the life of me understand why I was getting this message, and I was getting very upset !!!
I have a brand new Sandisk 2GB card, and it was driving me CRAZY.
My solution turned out to be a very simple one.
When your computer sees your card and you need to format it, it will give you TWO options. Either format using "FAT32", or just "FAT".
The FAT32 option gave me no results.
I tried again using simply "FAT", and it works just fine!
GOOD LUCK!
Jun 28, 2008 | Fuji FinePix F30 Digital Camera
Downloading mini video from finepix f30
Perhaps you can take out the xd card and use an external card reader to transfer the photos.
Mar 05, 2008 | Fuji FinePix F30 Digital Camera
Fuji FinePix F30 Digital Camera Logo
21 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
