Question about Innova EQUUS 3160 ABS CanOBD2 Code Reader & Scan Tool
Innova scan tool 3160 has blue screen no display
2005 GC shows a code c1. What does it mean?
the code should be longer.
my jeep has a huge list of C1xxx codes.
did you scan it first? that be FIRST.
only a real scan tool can show all codes.
the Innova 3160 scan tool does see all jeep codes. btw.
that is what I use. not ever working blind....
i have the FSM book on this jeep
scan it and we can help.
but i bet you dont want to buy one or rent one or have any shop in town do it....
Jun 09, 2015 | Jeep Cars & Trucks
Transmition light on what's the problem
in all cases, scan it, use a real scan tool and scan the PCM.
how you do that is your call.
buyone
rent one
get any shop (all can) do it.
the operators guide in the glove box states,
"get it serviced"
i use a innova 3160, scan tool it dont miss out on factory codes.
Oct 02, 2014 | 2004 Jeep Grand Cherokee
How do you read engine codes
any scan tool , is best.
code reader are near useless, about equal to a trip to autozoned.
get a real scan tool and see it all, get one that can read
all factory Jeep codes.
i use an Innova 3160.
Aug 18, 2014 | 2008 Jeep Compass
Reset the abs warning light ?
all anwers USA< other cars are DIFFERENT> 96 CAD usa.
it auto resets at every keyon.
get the FSM and read the ABS chapter. it tells you that and that it needs a special scan tool to find all issues.
if frisky pull the battery neg, lug, wait 5min,, or turn on head lights and foot brake if in hurry,, I never am.
and put back the neg lug. this will make the ABS start virgin.
why not post the symptoms. my light is on, why>/
1: brakes are bad. do a brake job.
2: scan the ABS see the errors. and the tests.
my nice Innova scan tool 3160 does not do 96
1997 -2005, cad
see chart, there is NO ONE scan tool for ABS that does all cars.
under $10000 .
my tool does most OBD2 PCMs. but not ABS or bags for many cars.
but does have a nice set of coverage.
http://innova.com/Content/Support/Downloads/051812_31X0b%20ABS_Chart_Final.pdf
Jun 24, 2014 | 1996 Cadillac DeVille
Which sensors & how would i know if its grounding.
why not post symptoms? first.? put us on the same page?
why do you assume its a sensor, much less grounding out.
try scanning the pcm. using any scan tool, (modern, not 1995 tools)
1: check fuse, test them/
2: check the engine (compression)
3: scan it. see what you have. we use the Innova #3160, to see all chyl. codes (dtc's)
Jun 05, 2014 | 2007 Chrysler Pacifica FWD New Cars
Dtc id 17
no year jeep GC?
the CEL means, this.
SCAN me.
get me scanned, DIY or take it to any shop , all can scan it.
best if car is newer than 2000 to use a scan tool that does jeep
factory codes, I use a innova 3160 to do that.
Apr 02, 2014 | Jeep Grand Cherokee Cars & Trucks
Innova scan tool 3160 manual
Don't need codes to have any number of problems
No misfire will ever be the same on your ford
Some coils set PO300 Codes,some show up on
a scan tool in Mode $06 under cyl misfires & some
coils you just have to walk a new one.
On a 2006 ALL the coils are bad by now, as well as the
front O2 Sensors
Change the Plugs every 3 years or every 2 on a 3 valve 5.4
or they will get stuck in there
Use the champion ones #7989
Feb 28, 2014 | Cars & Trucks
Innova EQUUS 3160 ABS CanOBD2 Code Reader & Scan Tool Logo
106 people viewed this question
Top Innova Measuring Tools & Sensors Experts
ray gallant
Vuk B
Tom Chichester
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
