How to connect a ballast mine went out now my lights dont go on
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Ballasts are only used on sets with a lamp---got a model number/brand and what the set is doing or not doing?
Posted on Nov 05, 2012
Wont turn on yellow light blinks 3 times pause and repeats no other lights on
If you can't get it on, you'll have to have a new Ballast assembly. Try unplugging it from the wall outlet. You may have to do this several times. Keep trying. If it won't start, probably the ballast. Always change the lamp with new if ballast gets changed. I got mine from Ebay.
Apr 14, 2014 | Toshiba 72HM196 72" Television
2004 acurs tl hid headlights dont work
Mine done the same thing and mine was the ballast.I tried the bulbs first as you did and didnt work .I found the ballast and the igniter at a great price together on ebay and replaced both and they work great now!!
Sep 09, 2012 | 2004 Acura TL
400 watt hps grow light just bought it but wont work!
Please review the following information.
https://www.sunlightsupply.com/page/technical-information-guide
Take care note of the discussion of connecting the ballast to the lamp housing and ensuring the ballast is NOT connected to the mains when the lamp housing is connected or disconnected from the ballast.
Also be aware the system will not allow you to turn it off and then immediately turn it back on again. There is a built-in safety feature to ensure the lamp and ballast are not damaged due to loss of utility power. There is a 10-minute delay built into the system in the event utility power is lost..
Nov 01, 2017 | Sunlight Supply 400 Watt Hps Sunsystem I...
New lamp and still blinking lamp light.fan running fast and pulsing turns on and off and temp light blinks when using remote no light from lamp
MIne did the same thing, thought it was the lamp, bought a new one....still did it, figured it wasn't the ballast because the light came on for about 3-5 seconds - was told the ballast was bad, the ballast supplies high power to the lamp - if it is weak, it will not supply enough power and lamp shuts down. Bought a new ballast on Amazon for $62.00 - problem solved. I also tried a cooling fan - NOT the problem, was the ballast
Feb 16, 2011 | Samsung HL-R6167W 61" HDTV
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
The UV light is not working on my 300307. How can I tell if it is the bulb, the ballast, or the transformer?
Read across both prongs of light with a meter set on ohm's to check for continuity(closed circuit) if no reading bulb is burned out. Mine attaches to the ballast and then is inserted into a glass tube wich is then screwed onto the housing. There is a micro switch attached to the ballast that setsmwhen insertet into the housing that might be bad(had to replace mine) Remove bulb and check if grtting power to it by inserting volt meter probes into receptacle for the light and check for voltage,set meter to correct setting. If getting power at plug for light ALL is good and it is your bulb
Apr 07, 2010 | Garden
Wire connection from lighting ballast
What you do is cut the wires from the old ballast that feed to the fixture end connectors then 'wire nut' the new ballast wires to the old wires.
Oct 02, 2009 | Electrical Supplies
Samsung 50" DLP Lamp died, new lamp will not light`
Bad news.  Mine did the same thing.  Mine is the 61", but the internals are basically the same.  I replaced the lamp and the problem was fixed.  Then after a couple days, it died again.  I replaced the ballast, to no avail.  Took it to the certified repair center and they said I needed a new DLP Light Engine.  They wanted $1250 to fix it, but I was able to order one online from partstore.com for $700 and fixed it myself.  No problems since.
Your certified repair center will charge a minimal fee to diagnose and then you can fix it yourself if you choose.
The easist fixes for the lamp problems are A) replacing the bulb and B) replacing the ballast.  Anything else, you'll want a certified tech to diagnose the problem.
Jan 17, 2009 | Samsung HLN5065W 50" Rear Projection...
Lam replaced
you dont reset it the ballast for the bulb took a ****.. i paid 300 for a new bulb and wasnt the problem then paid 150 for new ballast now i think the light engine went bad geeze
Sep 23, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
