Question about Wharfedale DVD-M3 DVD Player
Wharfdale Car Radio WH-180
Ive recently fitted the above into a Vauxhall Corsa, it works ok until you remove the ignition key then all the stations disappear you then have to retune it. There are 3 plugs coming from the car 1 has 10 input pins the other 2 only have 8 input pins its these 2 plugs Ive used, I havent changed any wires it was just plug and play! I think you need a 12v for the memory but where do you get that from?
    Sergeant:
  • 227 Answers
If you have access to the 8 pin plug and have a voltage tester check each pin with the ignition on. Once you have found the pins that have voltage see which one goes off w/ign. and which one does not. The one that goes off cut it about 2-3 inches from the plug and cap the end of the wire that was going to the plug. With the wire from the plug remove 1/2 inch or so of the insullation and find the pin that did not go off w/ign and skin that wire back about 1/2 inch and apply the other wire and tape up. this should do it.
Posted on Jan 04, 2009
Car radio not picking up stations
Check the radio earth, the aerial cable and the point at which the cable reaches the aerial.
If there is no fault, take the radio back to where you bought it.
Jan 20, 2014 | Car Audio & Video
Why does my radio on a Corsa Design 2007 only pick up the bbc radio channels? I have just bought the car.I have no arial on the top of the car.
You should have an Aerial mast on the roof of the car, it should be situated at the rear of the roof in the centre. All Corsa`s come fitted with an Aerial as standard so it should be there. If it is missing or broken then you will only be able to pick up the BBC stations as they have the strongest signal strength.
The Aerial consists of a base section attached directly to the roof and a mast which is removable from the base by simply unscrewing it, it`s not uncommon for the mast section to get pinched as it`s easily removable but they can be bought separately from any any vauxhall dealer and are easily replaced.
Hope this helps and thanks for using fixya
John
Dec 23, 2010 | Car Audio & Video
Radio code vauxhall corsa 03
Sorry...this code will only be available from the Main Dealer or a Radio Decoding Service.
Will not be available for free from anywhere on the Internet
Jun 15, 2010 | Car Audio & Video
I have recently baught a vauxhall corsa 53 plate.
This code will only be available from your Main Vauxhall Dealer or via a Radio Decoding Service such as your local Car Radio Store.
It will not be available for free from anywhere on the Internet
May 24, 2010 | Car Audio & Video
2001 Opel (vauxhall) Corsa key will not turn?
take it to vauxhall they will charge u but the spair key can then be recoded and the staering wheel is locked to the right because the corsa alarms had a fault then ever the car was lifted from the rear the alarm cutout because it thought it was on a tow truck makeing them easy to steal just cut the hand brake cable and pull on to a tow truck!!!!!!! so vauxhall made the steering lock to the right so as then the car wouldnt go on to a tow truck straight.
Jul 02, 2009 | DEI GM Immobilizer Bypass
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
Automatically goes to the demo mode on start-up
to turn off demo mode put radio into stand by were it is running demo mode and hold number 6 till it switches off. As for the key problem its the key that is making the key live connection on your model of car so this can not be changed. sorry
Apr 29, 2009 | Car Audio & Video
Radio code
there is now way u will get the code from any one but vauxhall as everyones is different 29.99 is the cost 4 a new security pass and they will put it into the radio 4 u
Dec 06, 2008 | 1990 Volkswagen Passat
Wharfedale DVD-M3 DVD Player Logo
134 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
