Question about Bissell 12005 Spot Bot Handheld Vacuum
Not spraying or collecting dirty water
Only the brushes are working it is not putting any solution on the carpet there is no liquid to vacuum up the carpet is dryafter the machine has gone throuth its cycle
  • Bissell Master
  • 18,389 Answers
It may be the pump thats blocked or needs replacing this video will show you how to dissasemble the machine..
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY#!
Posted on Nov 05, 2012
4 Suggested Answers
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
pippall
  • 1486 Answers
SOURCE: Pet hair and dirty water back on carpet
If you have followed the instructions.And your not happy i would return it.Get a repacement.
Posted on Aug 09, 2009
heatman101
  • 43501 Answers
SOURCE: the bissell carpet cleaner isnt spraying water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hjhdg
Posted on Sep 30, 2010
Proheat sprays the water but doesn't suck it back up
Your lid is not on tight on the water collection tank it can't create a section to pull the water out. Usually take it off and putting it back on will solve the problem. good luck& God bless
Angela
Aug 23, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
When button is pressed, water does not come out of the holding canister. still seems to have suction, but water doesn't come out to rinse/clean carpet.
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 22, 2010 | Bissell 9200 Upright Vacuum
I have bissell cleaner 8920 it will not release the cleaning fluid and water
If your machine continues to not spray, contact BISSELL Consumer Servies at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Pro heat 2x by Bissell does not put out or **** up water Brand is Bissell. Model is 8920 12 amp
If these suggestions do not resolve the issue contact BISSELL Consumer Services at...
1-800-237-7691
Sat: 9am to 8pm ET
Aug 15, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
the water head are pluged use a tooth brush and some hot hot water and brush it on the tips until they are unpluged
May 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 12005 Spot Bot Handheld Vacuum Logo
97 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
