Question about Amana NDE2335AY Electric Dryer
Amana dryer no heat
Everything works, except the heat, I cleaned the exhaust fan and tube and I borrowed a meter from a friend to check the componets, Its a digital one with lots of buttons, so the element reads between 9.7 and 10.0 and the ( not sure what they are called) their are 2 mounted to the element 1 reads between .002 and all 0 's its the black round one with red lable and the other is square and white and has no reading Then on the blower their are 2 more componets one fits around the other, the one in the center reads 0.000 and the outer one reads .574 from the info I gave can anyone help? Thanks
  • 686 Answers
No heat means chances are your heat element burned up
Posted on Feb 27, 2009
  • James Chandler Mar 02, 2009
    Change the square one with no reading that is your thermal fuse and it is blown.
My amana electric dryer model number "NED7200TW" wont heat up. Everything else works it just don't heat it just puts out cold air. The exhaust was somewhat clogged outside but even after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,./
Jul 27, 2011 | Dryers
My Kenmore Elite dryer works except there is no heat to dry.I am looking for suggestions to repair. Thanks
There is a moister sensor in your dryer that detects any lint build up inside the exhaust vents. If any obstruction is inside the exhaust tubes this sensor will put the heat in the check mode. Inspect and clean thoroughly and see if it will heat up again
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Dry will not blow heat
Check the entire exhaust vent tubing before buying anything for this dryer to repair.. Most dryers only need a good cleaning to get the heat back running correctly. A moister sensor is working if the lint build up is more than just dust in the vents tubes. Any build up the sensor detects and keeps the heat off. Sometrime you will get heat for awhile although it will shut the burner down quit soon
Jun 09, 2010 | Amana NDG2335AW Gas Dryer
Kenmore Electric Dryer will not Heat
Define checked everything. Usually when your dryer is not heating but blowing air its one of three things...
1. Thermal fuse in dryer
2. Thermistor in the dryer
3. Heating element in dryer
You need a signal meter with continuity check to accurately test all three componets. Normally the fuse and thermistor are in a set and cost less than 25 bucks. They are easy to replace if you are good with taking things apart. If the element is bad then you need to make sure your lint trap and exhaust hose are clean and kept clean. That is the main cause of the element burning up when it gets lint collected inside the dryer cavity.
In a pinch if the element is bad you can simply find where the metal has broken and try bending the rod so that it touches. The element has to be one solid piece so if there is breaks try and connect them back together until a new one can be purchased.
Please unplug the dryer before doing anything mentioned above.
Hope this helps
TankMurdock
Apr 27, 2009 | Kenmore 73952 Gas Dryer
Amana electric dryer will not heat....LEA60AW
check your wall vent to make sure it's not clogged,also check the fuse on the heater box it may have blown,without the fuse the heater will not work,you can check it with an omns meter-mike
Feb 23, 2009 | Dryers
Dryer heat output is 148, but takes several runs to dry clothes
You most likely have a ventilation problem somewhere in your exhaust line. This can be very dangerous and a fire risk. You need to do a thorough check of your vent pipe and make sure it is clear and the exterior trap door is working freely.
Jan 26, 2009 | Amana ALE643RB Electric Dryer
Amana dryer wont dry
Replace that square white one and it should start working.
Jan 12, 2009 | Dryers
Hello traceypecor,
I am attachinbg a link to schematics and parts list along with exploded views for you to reference but it sounds like you havge a bad thermal fuse and that will need to be replaced. The disk shaped sensors 9 reset themselves) when they cool down but the thermal fuse fails and stays that way.. http://www.pcappliancerepair.com/model-display.php
It may be item 6 in the listing
Let me know if that doesn't solve your problem and I will be happy to help you resolve this. BTW, make sure you remove or diasble power before making any component measurements of repairs..
Regards,
Rick
Nov 25, 2008 | Amana NDE2335AY Electric Dryer
Amana NDE2335AY Electric Dryer Logo
145 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you an Amana Dryer Expert? Answer questions, earn points and help others
