Question about Canon Pixma MP500 All-In-One InkJet Printer
My problem is error for printer canon pixma mp 550. The screen showes me error u072, some ink tanks are not installed properly. I think everythink is ok. How can I solve this problem? Thanks for response.
wormdunker69
SOURCE: canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Posted on Feb 19, 2008
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Posted on May 01, 2008
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
my printer say, "the ink absorber is full".
Posted on Dec 06, 2008
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
komguy
  • 2306 Answers
SOURCE: I have a Canon Pixma i90 printer and I keep
There's a small switch under where the ink tank goes on the left side of the carriage. You have to make sure you install the right side of the ink first, under the lip, and then press down the left side. When the switch goes bad, you need a new carriage which means you get a new print engine. Costs as much as a new printer.
Posted on Sep 08, 2009
How to reset cannon mp620 erroe code U072
U072 Some ink tanks are not installed in
place.
Install the ink tank(s) in the correct position.
This in write in service manual.If a have been useful pls give me a vote :)
Mar 07, 2011 | Canon PIXMA MP620 All-In-One InkJet...
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    ERROR 6000 ON MY CANON PRINTER MP550
    The front panel was open ON MP550 and had been hit by the a recliner. There is a sensor on that front door that detects that it is open. I had to take the front door off, reach in the slot on the left side of the opening, slide the sensor back up, and reinstall the door while holding the sensor up. Error 6000 went away!!!
    Nov 13, 2010 | Canon PIXMA MP540 All-In-One InkJet...
    My printer shows E 2 7. how can i fix it?
    i believe on this model the error code means that the ink tank is full...
    http://www.mediafire.com/?s2pa54m5z2wqwru
    this is a link to my hosting site where you can download the software reset tool for a the MP models...
    To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
    • Start with printer on then run this software
    • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
    Additional information error codes for the MP models...
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 = The connected digital camera / video camera does not support Camera Direct Printing
    E14 = The Ink cartridges whose destination are wrong
    E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
    E16 -E19 = Failed to scan head alignment sheet
    E22 = Carriage error
    E23 = Paper feed error
    E24 = Purge unit error
    E25 = ASF(cam) sensor error
    E26 = Internal temperature rise error
    E27 = Waste ink absorber full or platen waste ink absorber full
    E28 = Ink cartridge temperature rise error -
    E29 = EEPROM error
    E33 = Paper feed position error
    E35 15 = USB Host VBUD overcurrent error – USB
    E37 17 = Abnormal motor driver error
    E40 20 = Other hardware error
    E42 22 = Scanner error
    Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Everything was working fine, i ran out of ink in all tanks so i only replaced both black tanks they are in properly, well the light isnt blinking on them anymore it is solid red. but when i close the cover...
    Error U072
    Causes : * Some ink tanks are not installed in place.
    * More than one ink tanks of the same color are installed.
    Action : Replace all the ink tanks as they are empty. Confirm that the ink tank are installed in the appropriate positions.
    Hope this helps.
    Have a good day.
    Dec 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
    My pixma mp 145 is not working. it shows error 5.please give me its solution
    Error 5 means
    try to change your catridge if it is old one.
    Hope this helps
    Thank you
    Oct 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Canon pixma mp 145 E4 problem
    Dear Sir,
    Error Code E4 = No ink.
    Generally printer doesnt recognise refilled ink.
    Try the to reset the ink catridges
    by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
    Download Mp tool
    i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
    if you find any difficulty leave a feedback,we will glad to assist you
    good luck
    Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    E5 problem
    E5, says the ink cartridges are the wrong type, not properly installed, or not installed at all. You can't refill those without replacing the chip or resetting the chip. Many refilled cartridges just don't work...
    Aug 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Canon Pixma MP500 All-In-One InkJet Printer Logo
    27 people viewed this question
    old marine
    old marine
